How do you measure the Diamond SRH789 for optimal tuning? From the hinge or the bottom of the base?
T thom Member Premium Subscriber Joined May 26, 2003 Messages 273 Location New England Feb 18, 2014 #1 How do you measure the Diamond SRH789 for optimal tuning? From the hinge or the bottom of the base?
N nanZor Active Member Joined May 28, 2009 Messages 2,807 Feb 21, 2014 #2 I had this same question when I got mine. I reviewed it here: http://forums.radioreference.com/sc...views/220845-diamond-s-rh-789-telescopic.html Measuring from the hinge seemed to jive the best with an swr-bridge, but as always, what the antenna is connected to (swr bridge, scanner, bnc magmount etc) can affect those readings. Use the hinge as a ballpark starting point.
