ProScan: Difference between Remote Scanner Over IP & Web Server
Aviation_Scanner
WSEY205
Houston, Texas
What is the difference between remote scanner over IP and the web server options?
I would like to listen to/access my scanner over the internet before streaming to a wider audience as it were.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
In a nutshell: Remote scanner over IP requires another Proscan activation to work. One instance on one PC acts as the server, other instances connect to said server as clients
Web server: Access & control your scanner via web browser anywhere with an internet connection (firewall permitting, of course)
These are described in greater depth in the Proscan manual. Launch Proscan and choose Support > Manual
Aviation_Scanner
WSEY205
Houston, Texas
One step ahead ;)
Already looked in the manual and have set up my first web server, although it took me a while to figure out how to change one of my audio ports to line-in so I could pull audio from the scanner to the web server via an aux cable.
As always, thanks for the help
Enforcer52
Lake Livingston, TX
Turn up the volume in Audio Control, it is extremely low, have my computer volume all the way up and can barely hear it. But it is working, just need to play with Audio Control.
My web server audio is set to -3dB
eaf1956
Evansville, IN
Actually, the listener can use the CLIENT version without activation on RSOIP
