btlacer
KI4SJU/ Fire Captain/ EMTFR
I installed a radio shack "sputnik" discone antenna in my attic. The only place I could install it up there was close to a vertical beam. So the antenna is touching the wood of the rafters. Is this going to cause a issue? I am feeding the antenna with RG6 quad shield. Also I installed a half wave end fed HF antenna in the attic also. How far away should the hf antenna be from the scanner antenna?
