moonbounce
- Joined
- Nov 5, 2002
- Messages
- 1,452
- Reaction score
- 84
I did a lot of research for the discriminator tap, starting with Bill Cheek. None of them gave me a good decode while using DSD+ to decode digital signals so I tried my own version and got much better results. What I now have on two tapped scanners is a 10mf capacitor from the test point and a 33k omh resistor in series that is connected to my tape out on one scanner and a plug I put in another scanner.
First attempt was with a straight wire from the discriminator takeoff to the plug at the back of the receiver got about a 40% decode rate, added a 10 mf cap got about a 50% decode signal ( meaning that 50% of the signals got a good decode the rest were poor decodes ). Next I put a 12k ohm resistor in series with the cap and got about a 75% good decode. Next I took the 12K ohm resistor out and replaced it with 33k ohm resistor ( that was the highest value I had ) and now have 100 % clean signal.
Moonbounce
Moonbounce
