ProScan: distorted mic audio
Pr999
Allegan County, Michigan
I just got my computer back from the shop. After I set proscan back up, I plugged the same aux cable into both the record jack on the scanner, and the mic jack on my pc, and the audio is very distorted for some reason, I didnt have this problem before. I have a tower desktop. I've swapped the aux cord between the front mic jack and the back one, I already checked if I plugged it into the record jack, took out and reinserted the aux cable, and I even swapped it with a different one. Nothing changed whatsoever. What do you think the cause is and how do I fix it?
Solution
Lower the mic level. in the Win Mixer. In ProScan, click the Windows Mixer button. That will bring up the classic mixer. Right click on the mic and select properties then...
Pr999
Exactly what did the "shop" do to the computer? If operating system was reloaded or updated, you may have the wrong or basic sound drivers installed or drivers need updated.
they did have to reinstall the OS because I had them install two SSDs in a split system style, doesn't sound like a bad explaination.
ProScan
Software Provider
Ontario, Calif.
Lower the mic level. in the Win Mixer. In ProScan, click the Windows Mixer button. That will bring up the classic mixer. Right click on the mic and select properties then lower the level. First tune the scanner to a constant audio signal such as weather.
Solution
Pr999
I got around to trying this and noticed my microphone boost was the same as the one in this picture. I lowered it and my audio is back to normal.
