DIY J-poles
w2lie
New York DB Admin
Long Island, NY
I remember building a dual band copper J-Pole as a kid with my dad. Great project and helped me learn some basic plumbing techniques as well as how to tune an antenna at a young age. Seeing your project takes me back.
J-Poles are great antennas.
Somewhere I also have a home brew twin lead antenna that we built too.
KR4NIV
Asheville, NC
I made one for 6m once. It wasn't too long. Had to use 3/4" copper pipe.
I thought about that but, made a 6m dipole instead. Used 1/2 copper pipe.
pxl_20260705_162255635-jpg.203556
pxl_20260705_141301324-jpg.203553
Ubbe
Stockholm, Sweden
The j-pole are a balanced antenna and the coax are unbalanced so you will need a balun to properly connect to it.
The coax outer braid will otherwise be hot with RF and in many cases needs to be decoupled by winding up the coax in several turns as close as possible to the antenna and that will short circuit the RF to prevent the coax to be part of the antenna but will also loose half of the signal level.
/Ubbe
KR4NIV
Asheville, NC
/Ubbe
Thanks for that info. I plan on following this instruction on that calculator page:
"It is recommended to use some sort of choke at the feedpoint. Three turns (for 145MHz) of the coaxial cable around a 40mm former (PVC pipe etc), or taped up and hung freely is adequate. Five turns, 6cm diameter for 70MHz. I have also used a clip on ferrite or two for VHF. As with any balanced feed antenna, this will help prevent the braid of the coaxial cable from radiating, and becoming part of the antenna, and therefore affecting SWR and performance. You can check the effectiveness of the choke by touching the coax below the choke and if the SWR changes significantly, your choke is inadequate."
AK9R
Staff member
Super Moderator
Central Indiana
J-poles are an end-fed half-wave antenna. The feed point, being at the end, has a high impedance. The parallel elements at the end constitute a transformer, or matching stub, to convert the 50 ohm impedance of the feedline to the high impedance of the antenna. J-poles do not need a balun because they already have one. J-poles can benefit from common mode chokes to keep RF off of the feedline.
EAFrizzle
Bond. Ward Bond
SE de DFW
Speaking of J-poles, I miss cheap 300z twin-lead being available everywhere. With the right kite or balloon, HF J-poles ought to be doable. 😆
Ubbe
Stockholm, Sweden
So you are telling me that where the arrow points are a "cold" point carrying no RF and can be used as a ground by the coax? So why could it benefit from a common mode choke?
/Ubbe
Ubbe
Stockholm, Sweden
If I google j-pole and only filter on pictures I can see that perhaps 75% have the coax braid connected to the longer 3/4 wave element and the rest has it connected to the 1/4 wave element. Either will work as the two elements works in opposite phases. The end stub design only works as an impedance match and not as a balun. You can see on its design principal that both elements are "hot" and carries the signal but in opposite phase and will require a transformer balun to make use of the whole signal level.
/Ubbe
KR4NIV
Asheville, NC
If J-poles are so good then why do only hams use them? Why is it that you never see them on any commercial or government tower?
Maybe because Hams like to build stuff. These are pretty easy to throw together. It's a thing in every hobby I guess.
You can see on its design principal that both elements are "hot" and carries the signal but in opposite phase and will require a transformer balun to make use of the whole signal level. /Ubbe
Interesting point. Time for more research and learning. Antennas! :unsure:
popnokick
Northeast PA
J-poles are very sensitive to stray RF fields and influence from nearby metal objects, including feed lines. This makes them sensitive to other nearby antennas and PIM (Passive Intermod) found on tower locations. They also are often themselves emitters of stray RF from their feed lines. All of these characteristics may not be a problem for ham radio home stations, but make J-poles inappropriate for tower and other professional installations.
mrweather
Not to mention j-poles have no gain over an equivalent dipole. Most commercial antennas (4-bay, etc.) have much more gain.
One advantage they do have is they're DC grounded.
W4AXW
A Keeper of the 6m SSB Flame
Indeed some amateurs like to build stuff, especially antennae. It might be my favorite aspect of the hobby, but I try to build efficient radiators with minimal reactance and CMC issues. Unfortunately J-poles don't qualify.....
