Baofeng DM32 audio issues
ZS1DOV
I have searched the forum and many others but I don't find a resolution
I have programmed a digital repeater with TG/TS/CC
It acceses the repeater but zero audio. I can see the green LED light up and the signal meter, that there is activity
Monitor mode, or promiscuous mode - I activate it and it reverts to TG91 and hear chatted around the globe
The repeater is in my country (ZS) and would like to use it but zero audio. It's pretty frustrating.
I have the latest FW from Bao as well as the CPS to match
Has anyone had the same issue and have a solution to help me
Thanks and 73
lamarrsy
Rimouski, PQ, Canada
First, the obvious (sorry if it seems too basic, it’s just to eliminate this one) : have you checked the mic level sensitivity setting ?
Then of it is ok, try fumbling with the mic/ear connector, maybe with your programming cable (push-in push-out a few times).
This just to validate if it is not the mic connector that could have its internal contact « stucked » in the « hand mic » position, thus deactivating the internal mic.
I’ve seen that happen on a cheap UV-5R once.
ZS1DOV
Hoya
Thanks for you reply
Doubt it because TG91 came thru 5/9
