DMR 800MHz Pinellas County
baayers
Pinellas County FL
I was scanning the 800 band with my BCD325P2 and came across a DMR system that does not seem to be in the database. As of when I am typing this 860.7875 is active using CC7. In the time I have listened I have heard what sounds like garbage collectors, and someone speaking spanish. I'm in Largo and the signal is coming in strong. Unfortunately, the search function on the 325 doesn't give you a lot of info so this is all the info I have at the moment. I was wondering if anyone knew what this system is?
Thanks in advance
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Use the Frequency Data search to search statewide rather than visiting the county's DB page (fixed base is in different county):
860.7875815.7875CC 7
TG *
SL *
WQUC576Progressive Waste Solutions of Florida (used in Pinellas County)Industry
Industry
Industry
Hillsborough
FL
See if you can determine talkgroup(s) / slot(s) and update the DB with the missing info
CanesFan95
Analog already is interoperable.
FL
That frequency also uses LRRP which allows you to see the garbage truck locations on a map on DSD+.
