DMR Close Call
EarlSuitor
Berryville, VA
Does anyone know if the Close Call function works w/ a DMR radio? I can't seem to get it to work when TX on DMR. TY
rivermersey
Royal Oak, MI
Was told by Scanner Master that Close Call does not work with DMR. And that this was one of the future goals of the Uniden scanners.
racingfan360
Close Call doesn't work on DMR Simplex. It does work on DMR Repeater transmissions (in fact all Uniden radios with Close Call will hit on DMR Repeater transmissions).
UPMan
In Memoriam
Arlington, TX
Since DMR simplex is a 30ms duty cycle non-continuous signal, it will never trigger a Close Call hit.
racingfan360
It might be worth noting that most unidens will generally hit on DMR simplex when set on Discovery or Search & Store. If you know the band in which the DMR unit is operating this can be quite effective. Not as quick as Close Call obviously but it can prove very useful for tracking down those elusive channels.
