DMR Contact List
ProScan
Software Provider
Ontario, Calif.
Is there a way to import the DMR contact list into ProScan SDS200.
What type of scanner do you have?
Is the data contained in a document or a web page? Post a sample of the data here or a link to the web page.
kb2idx
"Open yer ears and shut yer pie hole! "
Bloomington, Indiana
i'm going to watch this thread with interest.
the contact list comes in a "CSV" format.
the sds200 has plenty of memory plus your SD card.
just hadn't even thought of this. i'm fairly sure that proscan
will accept csv files but haven't tried.
watching
de kb2idx
chris
VE3VMJ
Innisfil
Here is the list URL KF5IW DMR
I have a Uniden SDS200 and a registered copy of ProScan SDS200 with 3 CAL's
I would be interested in the ID # and the call sign attached
ProScan
Software Provider
Ontario, Calif.
The web page will import using the Get Clipboard function. No frequencies so the system will not scan.
1. Select the items in the web page
2. Create a Department under a DMR One Freq system
3. Click the Get Clipboard button
4. Select Continent or # Unique Callsigns column for the Text Tag
5. Click the Import button
kg4icg
Crazy Trucking Mechanic
Woodbridge, Va
Contact list is only DMR ID's of the hams and repeaters, why would someone want to load that in a scanner?
VE3VMJ
Innisfil
watching
de kb2idx
chris
No Go here. Contact list is larger than 1MB. will not load into scanner when selected.
ProScan
Software Provider
Ontario, Calif.
I give you slightly incorrect steps before. I see now that I should have clicked one of the continents and then the CSV file will download.
Here are the correct steps:
1. Create a Department under a DMR One Freq system
2. Click the Get Clipboard button
3. When the Get Clipboard window appears, click the "Filter Double Quotation Marks" check box and select comma for the delimiter
4. Click The button "1 Get From Clipboard Everything"
5. Select Channel Name for the callsign column
6. Click the Import button
Like I said before, the system will not scan or search without frequencies. You will need to create a site and add frequencies to it.
