DMR decoding setup?
Circa
OH/PA/WV
I'm trying to decode a DMR/TRBO system using RTL, SDRSharp, and DSD+.
I've been receiving data (Idle, SBK, Data header, MBC Header) with DSD+ and SDRSharp sitting on the Control Channel for the site.
That's all that's been happening, I haven't heard any voice.
Do I need to use something like Unitrunker and a second RTL stick to handle switching from the CC to the VC?
ME343
ME/NH/VT DB Admin
Gorham, ME
No. you have to make a .bat file for each digital mode. read the dsdplus.txt and it'll tell you what codes to enter etc.
Circa
OH/PA/WV
Is this the Advanced Tuning section that says I can use dsdstune to get the -dr# -dh# -ds# numbers?
I also added the CC and VC to the DSDPlus.frequencies file.
Edit: I started dsdplus with the advanced tuning switches mentioned above and I've still not heard anything.
Is the site maybe dead? I'm monitoring another site now, but haven't heard anything yet.
ME343
ME/NH/VT DB Admin
Gorham, ME
do I you have filter audio unchecked and also make sure you are using a virtual audio cable
Eric Harjula
Maine/NH/VT RRDB Admin
Circa
OH/PA/WV
Eric Harjula
I came to the conclusion that this system might not be too active or maybe it's just because it's Sunday. I also think this is a rather new system since the DB is still getting new unconfirmed tower sites.
I was able to get a short chirp of voice off of another site, so I think it's working correctly.
I'm going to monitor it later on and if it's still not receiving, I'll see what the Ohio forum says. It might just be a quiet system or too new to be very active.
Sent using Tapatalk
natedawg1604
Colorado
Sent using Tapatalk
Is it Conventional DMR, Capacity Plus or Connect Plus? Also can you post a screenshot of your setup?
Circa
OH/PA/WV
natedawg1604
Colorado
It's a trunked DMR and the Database page says Connect Plus.
The system is pretty dead again today, but I have a strong signal in SDR# and DSD+'s window is going crazy with Slot1 and Slot2 CSBK and Idle data. Still no voice though.
This is the system: Staley Communications - TRIConneX (WV-PA-OH) Trunking System, WV-PA-OH, Multi-State - Scanner Frequencies
Can you post a screenshot of your setup? Typically with Con+ you should get constant idle messages from the control channel, they would appear in your terminal log so make sure you're terminal log is enabled by starting DSD+ with -v[1-4]. Assuming you've got DSD+ parked on the control channel, all voice grants should appear in the channel activity window. Keep in mind control channels often rotate, so make sure you're parked on the currently-active control channel. (if you don't have Fastlane, you have to manually change the control channel whenever it rotates. The Fastlane version of DSD+ does this automatically).
Circa
OH/PA/WV
Circa
OH/PA/WV
Bandwidth in SDR# is too wide; 8k is plenty for DMR.
Audio gain is too high in SDR#.
Verbosity level is too low in DSD+; should be -v3.
also make sure to check correct IQ
I reduced my audio down to the 50db mark (~75%).
Started DSD with the -v3 switch.
Enabled the "Correct IQ" checkbox.
Using 8000hz bandwidth.
Been monitoring for about an hour and still no voice.
current launch commands are "DSDPlus.exe -fr -v3 -Pwav"
DSD+'s log reads like:
Code:
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR11 Con+ NL = 1 3 5 7 31
CACH Sig ERR2
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR21
+DMR           slot1         BS DATA       DCC=12  CSBK  ERR8  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  TLC  ERR10  ECC FAIL
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  CSBK  ERR10  ECC FAIL
CACH Sig ERR2
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR24
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR11  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA       DCC=12  Idle  ERR22
+DMR  CACH ERR slot1         BS DATA       DCC=12  CSBK  ERR14  ECC FAIL
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR12
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR8  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Unknown TypeC
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  CSBK  ERR14  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR10  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR16
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR11  ECC FAIL
CACH Sig ERR2
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR26
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR12  ECC FAIL
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR19
Sync:+DMR
CACH Sig ERR3
+DMR                slot2    BS DATA       DCC=12  Idle  ERR17
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  CSBK  ERR14  ECC FAIL
Sync:+DMR
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR8  ECC FAIL
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR29
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR18
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR14  ECC FAIL
CACH Sig ERR3
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR40
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  CSBK  ERR11  ECC FAIL
+DMR                slot2    BS DATA       DCC=12  Idle  ERR21
CACH Sig ERR2
Sync:+DMR
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR12  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR38
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  CSBK  ERR13  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR15  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR24
CACH Sig ERR3
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=12  CSBK  ERR13  ECC FAIL
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR32
+DMR           slot1         BS DATA  ERR3 DCC=14  Data Header   ERR13
CACH Sig ERR3
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  CSBK  ERR12  ECC FAIL
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR22
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR13  ECC FAIL
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR43
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR20
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=13  Unknown TypeB
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR13  ECC FAIL
+DMR                slot2    BS DATA       DCC=12  Idle  ERR15
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  CSBK  ERR9  ECC FAIL
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR7
+DMR           slot1         BS DATA  ERR3 DCC=12  CSBK  ERR10  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR26
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  CSBK  ERR13  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR10  ECC FAIL
+DMR                slot2    BS DATA       DCC=12  Idle  ERR23
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR21
Sync:+DMR
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=11  Rate 1/2 Data ERR13
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR26
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR3 DCC=13  PI Header  ERR11  ECC FAIL
+DMR           slot1         BS DATA  ERR3 DCC=10  MBC Header  ERR12  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Unknown TypeC
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=13  TLC  ERR12  ECC FAIL
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR42
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Idle  ERR18
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR21
+DMR           slot1         BS DATA  ERR2 DCC=12  CSBK  ERR14  ECC FAIL
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=13  Voice Hdr  ERR11  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=8  Unknown TypeC
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  CSBK  ERR11  ECC FAIL
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  CSBK  ERR10  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  CSBK  ERR14  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR29
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR15  ECC FAIL
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR3 DCC=14  Unknown TypeC
+DMR  CACH ERR slot1         BS DATA       DCC=12  CSBK  ERR12  ECC FAIL
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR41
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=10  PI Header  ERR13  ECC FAIL
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR31
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=14  Data Header   ERR11
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=13  Unknown TypeD
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=12  CSBK  ERR11  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=8  Voice Hdr  ERR14  ECC FAIL
Sync:+DMR
+DMR           slot1         BS DATA       DCC=12  CSBK  ERR12  ECC FAIL
Sync:+DMR
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR30
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR37
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Idle  ERR26
Sync:+DMR
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR23
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=8  Rate 1 Data
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR29
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  CSBK  ERR13  ECC FAIL
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR28
+DMR           slot1         BS DATA  ERR3 DCC=12  CSBK  ERR12  ECC FAIL
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR30
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  CSBK  ERR11  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR33
Sync:+DMR
CACH Sig ERR3
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Idle  ERR34
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  CSBK  ERR14  ECC FAIL
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Rate 1 Data
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR33
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  Idle  ERR22
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  CSBK  ERR12  ECC FAIL
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Idle  ERR35
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  CSBK  ERR15  ECC FAIL
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=14  PI Header  ERR14  ECC FAIL
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=13  Rate 1/2 Data ERR14
Sync:+DMR
Sync:+DMR
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR37
+DMR           slot1         BS DATA  ERR3 DCC=15  Rate 1 Data
+DMR  CACH ERR      slot2    BS DATA  ERR1 DCC=12  Idle  ERR29
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=10  Rate 1 Data
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=6  Idle  ERR24
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=7  Unknown TypeF  ERR1
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  Idle  ERR41
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  CSBK  ERR14  ECC FAIL
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=2  Rate 3/4 Data FEC FAIL
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA       DCC=12  Idle  ERR36
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  CSBK  ERR12  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=6  Idle  ERR36
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR36
Sync:+DMR
CACH Sig ERR2
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  CSBK  ERR11  ECC FAIL
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR26
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  Idle  ERR29
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA       DCC=12  CSBK  ERR13  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR27
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR42
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR23
CACH Sig ERR3
Sync:+DMR
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR6  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR17
CACH Sig ERR2
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR23
+DMR           slot1         BS DATA       DCC=12  CSBK  ERR10  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR15
CACH Sig ERR2
+DMR                slot2    BS DATA       DCC=12  Idle  ERR19
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=14  Rate 3/4 Data FEC FAIL
+DMR  CACH ERR slot1         BS DATA       DCC=12  CSBK  ERR10  ECC FAIL
Sync:+DMR
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=2  Rate 3/4 Data FEC FAIL
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=12  Idle  ERR24
+DMR  CACH ERR      slot2    BS DATA  ERR1 DCC=12  CSBK  ERR15  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR37
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR15
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=8  Rate 3/4 Data FEC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR1 DCC=12  CSBK  ERR11  ECC FAIL
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA       DCC=12  Idle  ERR26
Sync:+DMR
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR34
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Idle  ERR29
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=14  Unknown TypeF
CACH Sig ERR3
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Unknown TypeE
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=8  PI Header  ERR15  ECC FAIL
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 DCC=10  PI Header  ERR13  ECC FAIL
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=0  TLC  ERR14  ECC FAIL
Sync: no sync
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=13  Rate 3/4 Data FEC FAIL
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=12  Rate 1 Data
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=14  Voice Hdr  ERR13  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Unknown TypeC  ECC/RAS
+DMR                slot2    BS DATA  ERR3 DCC=15  Unknown TypeD
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=8  CSBK  ERR11  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR35
Sync:+DMR
+DMR           slot1         BS DATA  ERR1 DCC=12  CSBK  ERR9  ECC FAIL
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR28
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR21
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=12  CSBK  ERR15  ECC FAIL
Sync:+DMR
+DMR           slot1         BS DATA       DCC=12  CSBK  ERR11  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR  CACH ERR      slot2    BS DATA  ERR1 DCC=12  Idle  ERR23
CACH Sig ERR2
+DMR  CACH ERR      slot2    BS DATA  ERR1 DCC=12  Idle  ERR26
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  Idle  ERR20
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Unknown TypeB  ERR1
+DMR  CACH ERR      slot2    BS DATA  ERR1 DCC=12  Idle  ERR24
CACH Sig ERR2
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR35
CACH Sig ERR3
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR34
CACH Sig ERR3
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR29
+DMR                slot2    BS DATA       DCC=12  Idle  ERR29
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR32
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  CSBK  ERR12  ECC FAIL
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR35
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=14  Rate 1 Data
Sync:+DMR
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR3 DCC=14  PI Header  ERR13  ECC FAIL
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR22
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  CSBK  ERR9  ECC FAIL
CACH Sig ERR3
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR27
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=12  CSBK  ERR14  ECC FAIL
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=12  Rate 3/4 Data FEC FAIL
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=14  TLC  ERR14  ECC FAIL
CACH Sig ERR2
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR36
+DMR           slot1         BS DATA       DCC=12  CSBK  ERR14  ECC FAIL
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR2
+DMR  CACH ERR      slot2    BS DATA  ERR2 DCC=12  Idle  ERR33
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=14  Voice Hdr  ERR13  ECC FAIL
Sync:+DMR
+DMR           slot1         BS DATA  ERR3 DCC=10  CSBK  ERR12  ECC FAIL
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR33
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=10  CSBK  ERR12  ECC FAIL
CACH Sig ERR3
Sync:+DMR
+DMR                slot2    BS DATA  ERR1 DCC=12  Idle  ERR19
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=8  Rate 1 Data
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=8  TLC  ERR8  ECC FAIL
+DMR  CACH ERR      slot2    BS DATA  ERR3 DCC=12  Idle  ERR30
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=9  TLC  ERR13  ECC FAIL
Sync:+DMR
+DMR           slot1         BS DATA       DCC=12  CSBK  ERR13  ECC FAIL
+DMR                slot2    BS DATA  ERR2 DCC=12  Idle  ERR38
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  Idle  ERR24
Sync:+DMR
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR1 DCC=12  CSBK  ERR9  ECC FAIL
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 DCC=12  Idle  ERR31
+DMR  CACH ERR slot1         BS DATA  ERR3 DCC=12  CSBK  ERR15  ECC FAIL
natedawg1604
Colorado
Code:
CACH Sig ERR2
CACH Sig ERR2
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR2
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
CACH Sig ERR3
CACH Sig ERR2
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR2
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR2
CACH Sig ERR2
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync: no sync
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync: no sync
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR2
Sync:+DMR
CACH Sig ERR2
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
CACH Sig ERR2
CACH Sig ERR3
Sync:+DMR
CACH Sig ERR2
Sync:+DMR
Sync:+DMR
Sync:+DMR
CACH Sig ERR3
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
So, it appears you've got quite a few decoding errors. I would suggest using FMP instead of SDR#, that would allow you to establish a TCP link with DSD+ and eliminate the need to mess with audio gain settings. Once you have a decent signal from the control channel, leave DSD+ parked there for 12-24 hours and you should eventually see voice grants.
