BCD436HP/BCD536HP: DMR Moto Trbo
Executive1
WHITWELL
My scanner will only receive intermittent transmissions it might scan the frequencies for about an hour or more before it receives another signal this is occurring with all the DMR frequencies in my area of Marion county Tennessee. I have moved the scanner around different areas of the house. Have tried indoor and outdoor antennas. Use the scanner in Mobile use and all with the same results
Executive1
WHITWELL
Updated your firmware? (Assuming you've got Sentinel installed.)
The latest version has some fixes for DMR, particularly for MotoTRBO and Cap+ systems.
I have updated the firmware that makes no difference in the reception
cg
Connecticut
It makes a difference what kind of DMR signal you are trying to monitor. Is it conventional or trunked? If trunked, what type of DMR trunking? How do you know that you are missing calls?
Executive1
WHITWELL
Scanning a DMR Moto turbo trunk system. I know I'm missing calls because I have a Motorola police radio that I am receiving all transmissions on plus another scanner 160 handheld. I no, the frequency is very active so that's how I know where I am missing calls while monitoring the scanner
dmfalk
Eureka
Do the letters ENC appear from time to time? Some of the talkgroups might be encrypted.
cg
Connecticut
If it is a trunked system, you are not monitoring one frequency but multiple frequencies. They have to be programmed very specifically into the scanner. The only DMR with public safety in that county I see is the Mobile Comm America system. That is Cap+ which requires the LCN to be properly programmed. Verify that the LCN is correct.
Verify that the frequencies and talkgroups have not been locked out
Under that system in the database, there is a note that the Marion County users are switching to TACN (Statewide P25P2 system). Perhaps they have changed?
Executive1
WHITWELL
I have checked and rechecked the frequencies and talk groups appear to be installed correctly with correct lcns. This county is still using DMR multi-turbo mobile communications of America and has not changed to p25 as of this date. They have stated to me that they will not change the p25 for the next two years it seems the programming has to be right or it would not pick up the talk groups at different times
cg
Connecticut
Set up a conventional system in the scanner with just the 4 frequencies and set it for digital only. See if that makes a difference. You will have to listen to all the users and the rest channel keyups but that would be the only alternative if you believe your programming is correct.
