Dmr nxdn issues
Peerlessk
Lima NY
What would be the reason the sds200 just stopped receiving DMR NXDN ? I have two of the sds200 both with the upgrades . One receives the upgrades the other stopped . Setting are the same on both . Thanks
doovenator
Wenatchee, WA
You've checked squelch and filter settings? Does the one that quit picking up DMR/NXDN pick up anything? Problem with antenna signal through splitter/cable? That's a baffling one.
Peerlessk
Lima NY
Checked everything . I receive everything else . I’m stumped . It’s like the keys stopped working .
Peerlessk
Lima NY
Haven’t tried a new sd card yet . i haven’t updated the data base in several weeks . Service types all the same . its gotta be something stupid I’m missing
werinshades
Chicago , IL
Possibly turn off a system or site inadvertently? Go into Sentinel...Write to Scanner...Clear all favorites is where I'd start.
Peerlessk
Lima NY
I reformatted the sd card and for whatever reason this worked . both upgrades dmr nxdn working now . I have no idea why or how the upgrades stopped working . Not sure what happened the sds200 sits untouched monitoring a dmr talkgroup and it just stopped scanning dmr . Anyways a reformatted card worked .
