Got the paid DMR upgrade and installed with 1.07 firmware.
Reading the "DMR and ProVoice Added to BCD996P2 and BCD325P2 Scanners " article, it says to:
If you are trying to discover the correct settings for a new system, program the channels as conventional channels:
MENU -- > Program System --> New System (or scroll to existing list to use and press E)
Conventional, then E/Yes to confirm
Edit Name, if desired.
Edit Group -- > New Group
Edit Channel -- > New Channel then input the frequency.
Set Audio Type -- > Digital Only then set Search (for any Color Code) or Set DMR Color Code and select the code used by the service.
OK, great, I did just this thing with a local resort setup of four frequencyies as found from the excellent site:
Digital Frequency Search
Next, the DMR upgrade post says:
During conventional scan, when the scanner stops on a DMR transmission, the following information will be displayed:
DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code, if you selected Search when programming the channel.
CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code, if you selected Search when programming the channel.
CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), the received color code if you selected Search when programming the channel.
DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code if you selected Search when programming the channel.
Absolutely thrilling, get nothing of the sort, did someone forget to add just what the heck do I do with this fantastic new knowledge on the off chance it is shown?
I get noting of the sort shown n any of the three display options. FWIW, the DMR system I programmed in comes up on just one of the four frequencies, has no displayed info other than "DSC047" which does me no good far as I can tell.
Am I missing further instructions how to program DMR that were posted somewhere?
