Tim-B
- Joined
- Nov 17, 2016
- Messages
- 539
- Reaction score
- 78
When monitoring the frequencies of a local communications company that rents radios to local businesses for use on the comm company's repeater I noticed that many DMR transmissions stay muted while others have good audio. I thought it was maybe a problem in the way that I programmed by scanner but I noticed the same thing happened with multiple scanners and also an Alinco DJ-MD5 business radio in promiscuous mode and also when monitoring those same frequencies with SDR# with the Simple DMR plugin. When using all DMR capable scanners I own, and the Alinco, and airspy/DMR#/Simple DMR at the same time I noticed that either they will all recieve the transmission with no problem or all of them will stay muted at the same time when there is a transmission. So my question is - are these encrypted DMR transmisisons where the audio stays silent? If so then why does my Uniden 436HP not say "enc" on the display or is the 436 not able to tell if a DMR transmission is encrypted?
