.... I am finding monitoring DMR and NXDN to be much easier with the TRX even thought it is not truly trunking.
Whistler and Uniden have different patents and use different techniques to monitor digital systems.
Some systems will let the Whistler excel and on other systems the Uniden will perform better.
Try and use each scanner where it perfomes best.
Generally speaking on a big trunked system the Uniden will do better. With medium and small systems that have low to medium traffic intensity, and not use super many frequencies on each site, the Whistler is doing a better job.
I don't know what they mean by saying that the Whistler doesn't have full functionality in DMR. It often performes better than a Uniden that skips active conversations way too often.
If there are a private mobile-mobile conversation in a system the information on the control channel are only sent once and if you do not scan that frequency when the call is set up you will loose it totally with a Uniden scanner while the Whistler will let you monitor all private calls at all times as it scans the actual active voice channels.
I have commercial DMR radios monitoring systems and the Whistler never miss a talk group call while the Uniden sometimes skips the call setup and comes in late or continues to scan to the next system as if it never where a call on the system.
Whistler have other issues like a small display with minimal information, terrible keypad buttons, a squelch that lives it owns life, bad RF performance in some frequency bands, no multiple search ranges, CTCSS/DCS search are awful. But instead have an excellent audio recording system, superior LED light indication, detachable front panel, great audio quality from speaker, discriminator output, parameters like delay can be set to any value up to 60sec, a sweeper function that catches transmissions from a great distance.
You really need scanners from both Uniden and Whistler to be able to satisfy most of your needs.
/Ubbe
