(partial repost here)
I bought & have tried to use IC-R5 programming software w/o any luck. Also tried the tk5 but couldn't get it to run w/o crashing (on two different PC's).
This little bugger is kicking my a**. I've spent a number of hours trying to load frequencies & other then the default config. provided with the IC-R5 software I can't. I hate to surrender but the R5 may have to go on the block. 1st electronic gadget that has ever beat me.
Here's the main issue. I can load a single .icf file, either the default freqs. or a .icf file downloaded from the Percon site. But I'm not smart enough to ADD/COMBINE frequencies to an existing file.
What I want to accomplish is to load the default config. & then add additional groups of frequencies from the Percon database. But I'm unable to ADD from the database. When I import the files they just overwrite the current frequencies. Plus AFAICT there isn't a way in IC-R5 to select more then one line/frequency at a time. Rather then select a bunch of frequencies to move them to other channels/banks, it must be done one-by-one.
Then I found a download of the OEM Icom R-5 software. Worked for 2 hours trying to get that software to 'find' the R-5 (yes, I changed the com port to 2, has to be on port 1-4). So I can't comment on the OEM software yet.
One thing I'm wondering about, is my programming cable. I got it with the radio used & it isn't the OEM cable, appears to be a eBay cable. I wonder if I ordered an OEM USB cable if I could connect with the OEM software?
Grrrrrrrrrrr Anyone want to buy a Icom R-5?
