Does anyone know what this is?
hamfan22
Houston, Texas
I just received my Tk 3180 and I popped the option board area open and saw this. Does anyone know what this board is? It is soldered and doesn’t use the white connector which to me seems a little odd.
vagrant
ker-muhj-uhn
California
I think that may be a solder version of the voice scrambler board (SC20-460). I could be wrong, but the manual shows that optional board connects to the TXD1 (PTT), which correlates with your photograph. Additional solder points do as well except for point 5A. The manual does not show it connected to that point.
Hmm...yes, one of the wires is connected to 5A instead of SB2.
5A = 5 volts 78mA max
SB2 = 7.5V typical with 100mA max
Perhaps that particular voice scrambler board needs less juice. If it works you're good.
mancow
N.E. Kansas
It doesn't look like any 460 board I've seen. Could be a scrambler from Midian or other brand.
KK6ZTE
California
If you remove it, please note you'll likely need to reinstall 0 ohm resisters to direct audio back to the transceiver instead of the scrambler board. Best to leave well enough alone
ecps92
Taxachusetts
Looks like the ole Midian Scramblers
View attachment 74303View attachment 74304View attachment 74305
