does anyone recognize this interference?
Jim_Shaffer
For the past week or two, I've been seeing this pulsing interference across almost the entire HF spectrum. It's most visible here in the amplitude plot from 18-25 MHz due to the lack of other signals at the moment, but in the waterfall you can see it going down to at least 5 MHz. The other streaks that start at 0 and peak around mediumwave are probably lightning, and I suspect that the garbage from ~1500 kHz to ~3500 kHz is DSL, but I don't think that this new interference is DSL because first, I still only have 3 Mbps ADSL on my road, and second, it's not there full-time. Sometimes hours will go by without it, other times it's almost continuous.
krokus
Southeastern Michigan
The two most common sources:
Switched mode power supplies.
Plasma TV/monitor.
It is likely to be from a neighbor's house. Using a small AM radio, and walking around the neighborhood with it, would help you localize the source.
dlwtrunked
A common cause of interference like this is certain "reverse rotation" clothes washing machines. For that reason, due to a neighbors, I do not listen on Saturday mornings.
Jim_Shaffer
The spectrum looks a bit like grow lights, but it pulses on and off, at random times, so it's almost certainly not. (Also, do they wipe out 0-30MHz like that? Mine only wipe out longwave.)
IC-R20
LoBand Nation
Oh yeah I have one of those PWM motor new washing machines and it sucks. The noise travels really far and unlike when I had a plasma TV or a bunch of incandescent Christmas lights I can’t just walk out to the sidewalk with a portable or use the 10m groundplane on roof to get out of it.
Probably just a coincidence but I heard one of its noise sweeps at the same time on an SDR 110 miles away at the same time it happened on my local radio.
