Dothan Al Comm update
millam
Old Radio Guy
Dothan's comm system has changed. System ID BEE00-46B, site 6.1 and NAC 460. This enables it to
connect with the AIRS (Alabama Interoperable Radio System). The PD dispatch is still clear, don't know
about the fire dept. The TG for this dispatch is 60316. Seems that the only thing that changed was the
system numbers to align with AIRS. Dale county is the only AIRS system close to Dothan that I know of.
Dothan PD has a web site that has calls listed and a map of those. Google Dothan PD and look at the
pull down menu's.
Mil
jmichjr
pull down menu's.
Mil
Mil
What are the frequencies?
Is it the Houston county frequencies located on the AIRS system?
Imma try to listen to Dothan Fire that Drummer2015 advised
Or maybe he can reply as well @drummer2015 with the frequencies to use
millam
Old Radio Guy
Mil
The frequencies DID NOT change, just the system id, site ID, and NAC like I said. Just change these 3 things in your scanner if they are used, I use DSDPlus, not needed. No the Houston County Comm system is not connected to AIRS, system ID for AIRS is 46B or 00A I believe, and AIRS is P25, Houston County is NEXEDGE96.
Mil
millam
Old Radio Guy
millam
Old Radio Guy
I just discovered ne talkgroup numbers and edited those in my scanner. took less than 5 minutes.
Here is a list that DSDPlus found. I had Dale County comm and Dothan Comm running. If you can ID any of these let us
know. Quite a few clear and a few encrypted. We can update RR database after a few days with the new TGs maybe.
WX4AJM
Austin
Ozark, AL
MilView attachment 141601
School and/or Bus TGIDS:
60035
60038
60040
60195
60198
60199
Possible TGIDS:
60055 Dothan Public Works
60197 Dothan Leisure Services
ONLY Radio Tests (as of 5/14):
60013
60016
60017
60023
60109
60110
60128
60129
60259
Heard EMS on 60271 a few times. Fire others.
I am recording in search mode on ProScan and reviewing at end of day.
KG4KHQ
High Point NC
Before I start some reprogramming, I have a question. In this thread the talkgroups are showing to be in the 60000 series of ID’s. In the new database update yesterday they are showing to be in a 4 digit range. It appears the talkgroups from the original Dothan P25 system were moved to the AIRS system in the database. Which set of talkgroups is the correct one? I’ll be down there in a couple of weeks to work on it but I was curious about the difference.
drummer2015
Dothan, Al.
The talkgroups updated yesterday are the old talkgroups The new ones are 5 digits starting with a 6. Houston County is not on the Dothan System. The have a new Nexedge System which they began using last year.
millam
Old Radio Guy
Dothan Pd TG 60316, Dothan Fd TG 60261. They are clear, rest of the Pd and Fd TG's are encrypted mostly I believe.
Other city of Dothan services are on this system, have not listened that much. This is the Houston county system:
Houston County Trunking System, Various, Alabama I received an email that RR had made the changes to Dothan, have
not had the time to look at it, I will change the TG's sometime next week I hope.
Mil
WX4AJM
Austin
Ozark, AL
Here's what I have so far as of 05/24.
Testing channels have only been heard testing at some point and may or may not be relevant further.
Code:
# SYS    - Dothan P25
# GRP    - Dothan Primary
60055; Dothan PW
60197; Dothan Leisure
60261; Dothan FD/EMS
60271; Dothan FD/EMS
60272; Dothan FD/EMS
60316; Dothan PD Disp.
# GRP    - Unconfirmed
60105; Dothan 60105
60179; Dothan 60179
60257; Dothan 60257
60325; Dothan 60325
60337; Dothan 60337
# GRP    - Schools/Bus Channels
60035; School
60038; School
60040; School
60195; School
60198; School
60199; School
# GRP    - Testing
60013; Test 60013
60014; Test 60014
60016; Test 60016
60017; Test 60017
60023; Test 60023
60027; Test 60027
60033; Test 60033 (Bridged Channels?)
60078; Test 60078
60079; Test 60079
60105; Test 60105
60108; Test 60108
60109; Test 60109
60110; Test 60110
60114; Test 60114
60128; Test 60128
60129; Test 60129
60138; Test 60138
60139; Test 60139
60167; Test 60167
60176; Test 60176
60246; Test 60246 (Bridged Channels?)
60259; Test 60259
I believe @codeplug and I have found a few of the encrypted TGIDs. We'll see them pop up in ProScan with no log or audio.
I haven't decoded this long on SDR to know for sure.
Code:
# GRP    - (E) Encrypted
60049;
60056;
60066;
60067;
60068;
60114;
60208;
