Veronica71
I want to build an antenna for 2100mhz lte. I am following these instructions: Double BiQuad sector antenna for IMT 2100 MHz / 3G / HSUPA / HSDPA / HSPA+ / LTE
But when i use the calculator, dimensions is a bit different: BiQuad Antenna Calculator
First one from Double BiQuad sector antenna for IMT 2100 MHz / 3G / HSUPA / HSDPA / HSPA+ / LTE
And calculated one is like so:
RH value is 15mm for first one and it is 15.7mm for calculated one. Other dimensions is a bit different too. What should i do? If i build the antenna with a little incorrect dimensions what would happen? It does not work at all or it will work but gain is not too much?
I am a newbie for constructing antennas, please help me. Actually i made a cantenna and biquad for wifi before but they didn't perform as i expected.(cantenna was better than biquad) But this one is important. I bought a cell phone repeater to use in village and i will attach the antenna to it when i build it.
Thanks for reply for now
(Sorry about grammar mistakes that I made, I am not native English speaker)
