Double ISO Setup Pics
UFEMTFF
I was going to ask you why you mounted both units so deep into the dash kit, but once I scrolled down I understood.
Pretty cool
garys
Central Texas
What type of vehicle is this? I'm interested because I'm thinking about doing something like this in my 2006 Tundra. I have a Sony Stereo that is single DIN sized. It looks as if I can get both radios in there with no real trouble.
Any hints on doing this?
Michigan
Did you install the Sony? Can you post a pic of your dash on a new thread/post, and I'll see how I can help you.
Basically, you need to find out if your truck can accomodate a double Din radio. If so, it should work. You'll have to purchase an installation kit for a double din that's specific for you vehicle.
garys
Central Texas
I'm not sure if you're replying to me or not, but I'll answer anyway.
I haven't installed the Sony in this Tundra, but took it out of my 2001 Tundra earlier this week. I installed it in that truck last year. Since the OEM radio is double DIN, the radio kit came with a small bin that took up the space below the radio. The Toyota bracket is designed for a DD radio, so hopefully there will be some holes that will line up with the holes that Uniden put in the 996T. If I need to, I'll put a strap at the back of the radios, both of which are threaded for M4 bolts.
There really isn't a reason that it shouldn't work. I just have to find a space for the XM direct and adapter boxes, but those might go lower down where the OEM radio amplifier sits.
The only real PITA will be if I have to take the 996 out for service, but even that's not a major problem.
I've done about a dozen stereo installations in a variety of Toyotas and they have all been pretty easy to work on.
Gary
guttapercha
very sweet!
That is a great install. I am interested in doing the same thing and I'm wondering if you could give me your opinion.
Do you think the same thing could be done with this double DIN
fascia: (05 Toyota Tacoma)
Michigan
It looks like it will fit. Both radios will be recessed.
Would you like better pictures of what I got or dimensions? Just let me know.
guttapercha
Yes, the recessed look is a little different, but I can live with it.
Theoretically it should fit if the face of the stereo receiver isn't too much taller than the standard DIN height. I'll let you know if I need measurements for sure - thanks!
JD
fd71022004
Alpine
Does that Alpine have switchable display colors?
If so do you know how to change colors?
I bought one used, no manual.
John
Michigan
John
Hi John,
Sorry for the delayed response, I've been hanging out in model train forums. Anyhow, I don't think you can change the color. I've never figured it out myself.
You should be able to download the manual from
www.alpine-usa.com
