Douglas County - Douglasville GA TRS
4phun
The information on the control channels for the Douglasville GA TRS system is incorrect on RR.com.
http://snipurl.com/71ef
PRO-96 dump
DOUGLAS*3930, 856.93750, MOT, 0.0, D
3930 SAT6-12 , 857.23750, MOT, 0.0, D <--- add
DOUGLAS*3930, 856.76250, MOT, 0.0, D
DOUGLAS*3930, 857.43750, MOT, 0.0, D
DOUGLAS*3930, 857.76250, MOT, 0.0, D <--- delete
Add 857.23750 and delete 857.76250 which is incorrect.
I checked ScanAtlant and Mike has it right.
Also a couple of new IDs for you to figure out.
ID# 08784
ID# 08816
ID# 00816
Keep and eye on this system, it is destined to become a large multi county W GA regional APCO trunking system. I can pick it up in Smyrna out in Cobb county.
PRO-96 TIP
I had the ones from rr.com and it did not have a viable control channel today. Panic - no! Just take the lowest one and from PRO-96 manual hit FUNCTION TUNE
Un PAUSE the tune and let it search upwards for a control channel.
When you find one hit FUNCTION PROGRAM (enter bank and chanel number) ENTER.
Hit MANUAL and check the Sys ID. If it isn't the one you need go back to tune and try again.
In a few minutes you will find the missing control channel. I always make a text tag for a control channel with the Sys ID in it so I can remember which trunking system it goes to.
See the PRO-96 dump above for an idea how I enter raw data along with known data.
Vic
