Hi! I am having a problem with programming some DP3400’s (XPR6300’s I believe for those over the pond), and hoping that somebody may be able help as I’m struggling to resolve the issue.
When I plug the radio in, I get a positive device recognition tone in, and It shows up in Device Manager under network adapters, but with an orange triangle. Expanding the detail, It says ‘The device cannot start (code 10). The device does not show up In network and adapters as an ethernet device either. I’ve tried a few radios and all show this error.
In contrast, a DP4600 shows up with no orange triangle, I get the windows discovery network permission pop up, and the radio appears as an ethernet connection, using the same cable, as does a DP1400 which uses a different cable.
I’ve tried uninstalling the driver and re-installing, uninstalling CPS and reinstalling, and tried on another PC, but still have the same issue with the DP3400’s.
Any help would be very gratefully received.
Thank you 🙏
Thank you 🙏
