BOBRR
Hello,
Have an HP1 and using Butel's ARC software for programming it.
a. Thought I would play around for the first time with the CTCSS and Tone options.
Have never used them before.
Am interested in monitoring the Sudbury, Mass. PD, (852.9125) which I have been monitoring in the "normal" way without any of these codes or tones.
In the RR database, under Tone for the Sudbury PD, it shows "023 DPL"
Can someone please interpret what this is, and means, please ? What is DPL ?
Is it similar to the CTCSS mode, or...?
In the Butel software, under SQ Mode, or SQ Code, there is nothing in the pull-down
menu that gives this as a choice. Why ?
If someone could explain this for me, would be appreciative.
General questions on:
b. If you do enter a CTCSS Code, where applicable, via the Butel software, does the radio automatically use it, or must some option be set telling it to first ?
c. What screen does one go to to on the Radio to see what, or if, a Code is being used for a particular Channel ?
Regards,
Bob
Regards,
Bob
