DSDPlus DSD+ Event Log Input Setting Keeps Changing
CanesFan95
Was Homeboys-Scanna
Banned
FL
When the rest of us are running 2.37, it's kind of a given.
Experiment? Easy enough to try each of -_1 -_2 -_4 -_8 and see what window gets minimized.
It? Is it DSD+? If so, you don't have to do anything for it to remember window positions. Just move them and they'll be there next time.
It doesn't remember the window position for FMPA. If I drag the scope display around and put in a certain spot, then close out of everything, then re-open the .bat file, the FMPA scope goes back to the original spot and not where I moved it.
CanesFan95
Was Homeboys-Scanna
Banned
FL
So what's the difference between "TCP Linking" and "Direct Linking"? I don't understand what those mean.
CanesFan95
Was Homeboys-Scanna
Banned
FL
FMPA 2.37
Added direct connection mode; see FMP24 notes above.
Added DLL files integrity checks; see FMP24 notes above
I can't find which file that screenshot is from. I've tried experimenting with -_ every which way and can't figure it out. Basically, I'd like to minimize all console windows and all -rv instances. It would be nice to make it minimize everything except the -cc instances of FMPA, the Event Log, and the Channel activity.
cg
Connecticut
See the part that says Sum values to minimize multiple windows in post 19?
Sum means to add, so if you want Console and Source audio you go 1+2=3 therefore by entering -_3 the program will minimize both.
