DSD+ Fastlane NEXTEDGE48 Frequency file setup
erickirchey
Lebanon, MO
I have been trying to figure out the frequency file I have got FMP24 running on the one frequency but would like DSD+ to scan two active frequency's.
I have watched several youtube videos but the networkID, siteNumber, OTAchannelNumber do not seem to apply to the system I am actively listening to. what would i insert here as at the bottom of DSD+ 1R event log does have these at the bottom.
Reconrider
Inside the Galaxy
Radio Galaxy
Post the current information you have and I'll get it setup up for you. It took me awhile to understand how to do it
(see below for example and post info if you need help still)
Dsdplus frequencies file format
; protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
NEXEDGE48, 2, 3, 0, 464.11875, 0.0, 0
Set yours up like mine is here(or copy and edit it).
Swap the 2, 3 and frequency out for your info that you have(rr or dsd giving you the info)
Leave the rxfrequency, sortorder alone.
If you know the channel number, put that in - remember it's LSN not LCN like uniden scanners are
dave3825
Suffolk County NY
THese 2 freqs, if they part of a trunked system, then you would need the info.
If they are stand alone conventional, then you would set up the fmp24.scanlist file to have it scan those.
