DSD+ FastLane P25 No Longer Decoding
AB9NN
Beulah, MI
I use the following two lines of bat code to start my radio and tune the known strong signal. The output below is what I am getting from it. It doesn't seem to be loading the frequency and trying to tune it. Can anyone point out what might be wrong with my code? Thanks!
START FMP24 -rc -i1 -o20001 -P0.0 -f853.9625 -_2 -g47 -b12.5
START DSDPlus -r1 -e -T -E -Pwav -i20001 -O NUL -_1
maus92
OCMD
Has the control channel changed?
DaveNF2G
Latham, NY
What role is DSDPlus configured as? It looks like you have a control channel monitor with no voice follower.
AB9NN
Beulah, MI
It's a P25 system, so there is only a control channel to start....
RMason
Mississippi / Colorado
The FMP24 console output indicates that it has tuned to 853.9625. I recommed removing the -_2 option in the FMP24 command while you debug this so that the spectral display is not minimized (or manually maximize the window). This should allow you to visually see what FMP24 is doing.
AB9NN
Beulah, MI
Great question! Just confirmed it is the same control channel, although the database lists two control channels for one site.
maus92
OCMD
Has your dsd configuration ever worked?
Sites always have at least two frequencies designated as control channels (Motorola); some sites can use any site frequency as a control channel (L3Harris and others). I am assuming that you have verified 853.9625 is the current / active control channel.
Looks like this is the Honor site, correct?
Also noting that you are not applying any ppm correction and are using a significant amount of gain. Most sdrs require some ppm adjustment, and too much gain can be a bad thing.
RMason
Has your dsd configuration ever worked? Sites always have at least two frequencies designated as control channels (Motorola); some sites can use any site frequency as a control channel (L3Harris and others). I am assuming that you have verified 853.9625 is the current / active control channel. Looks like this is the Honor site, correct?
From the OP's location:
The other control channel listed is 853.4625.
AB9NN
Beulah, MI
This has worked with this frequency and no Parts correction for several years.... DUHHHHH... I JUST got it working! I had inserted a LNA with a strong filter in it for decoding Russian weather satellites and it seems it had totally knocked out this strong signal! Impressed by the strength of the filter! My bad - sorry to bother everyone. Thanks for the tip on eliminating the -_2 to see the spectral display!
dave3825
Suffolk County NY
Depending on the version of Fastlane you are running, you may be able to eliminate a few more things.
notes.txt says;
DSD+ 2.516
*** Make a backup copy of your DSDPlus.radios file. ***
Due to a file format change, this update will discard
all Motorola talker alias data that is present in your DSDPlus.radios file.
This update will reacquire your talker alias data from the DSD+ talker alias server.
Removed -t -T and -E command line parameters.
notes.txt said; DSD+ 2.441
Some command line options and keyboard commands have been removed.
DSDPlus -h lists all command line options and keyboard commands.
maus92
OCMD
Initially mentioning a change in your signal path would have been informative.
saioke
You're lucky. I've heard that using an LNA and tuning to strong signals can overload and destroy your SDR. Never attempted it myself.
