DSD-FME not showing encryption details and AMBE frames
dolman
Might be a silly question, but I’m monitoring a few DMR frequencies in my area. They’re all encrypted, so I can’t decode the voice, but I’m trying to gather as much info about them as possible. I’m using DSD-FME with the -Z option to figure out encryption algorithm, it shows it just fine:
Code:
Slot 1 DMR PI H- ALG ID: 0x21 KEY ID: 0x03 MI: 0x1BA6129B[0m
[36m DMR PDU Payload [21][10][03][1B][A6][1D][B9][00][00][03][5C][2D][0m
13:05:24 Sync: +DMR   slot1  [slot2] | Color Code=01 | IDLE
[33m Activity Update TS1: Group Voice; Hash: 9; TS2: Idle; Hash: 0;
 SLCO Completed Block [18][00][90][0A][00]
[0m
13:05:24 Sync: +DMR  [SLOT1]  slot2  | Color Code=01 | VC1*
 AMBE 0BD6F009CF1780 err = [0] [0]
 AMBE BC83A6FAD55500 err = [0] [0]
 AMBE F480F302AB4080 err = [0] [0]
However, there are a few frequencies with pretty strong signal where I don’t see encryption details or AMBE frames in the log:
Code:
22:05:31 Sync: +DMR   slot1  [slot2] | Color Code=11 | TLC [31m
 SLOT 2 TGT=200 SRC=59028 FLCO=0x00 FID=0x10 SVC=0x40 Group [31mEncrypted Call [0m
[36m DMR PDU Payload [00][10][40][00][00][C8][00][E6][94][1E][AA][8E][0m
22:05:31 Sync: +DMR  [slot1]  slot2  | Color Code=11 | IDLE
[33m Activity Update TS1: Idle; Hash: 0; TS2: Group Voice; Hash: 118;
 SLCO Completed Block [10][80][07][60][20]
Any idea why DSD-FME wouldn’t show this information on those frequencies?
dolman
I’ve sent you a private message with the captured samples.
dolman
Mystery solved – DSD-FME doesn’t show the PI header or Encryption Identifiers because those transmissions are secured with simple Motorola BP keys. Thread may be closed.
dolman
Hello again Iwmobile,
Hope you don’t mind me picking your brain once more. I’ve come across a slightly odd DMR system nearby and was hoping to get your thoughts. There are four frequencies, all transmitting the same DMR traffic in parallel, perfectly time-synced, so I’m guessing it’s an IP Site system. The traffic’s minimal, and when I managed to catch a bit on one of the frequencies, DSDPlus didn’t show any AMBE frames.
Would you mind having a quick look at the log below? Just wondering how I should interpret this. I have used the following options to run DSDPlus: -fs -Z -N 2>/home/log.txt
SLOT 2 TGT=205 SRC=56543 FLCO=0x00 FID=0x10 SVC=0x40 Group [31mEncrypted Call [0m
[36m DMR PDU Payload [00][10][40][00][00][CD][00][DC][DF][EC][3C][C5][0m
20:11:55 Sync: +DMR [slot1] slot2 | Color Code=11 | IDLE
20:11:55 Sync: +DMR slot1 [slot2] | Color Code=11 | TLC [31m
[36m DMR PDU Payload [00][10][40][00][00][CD][00][DC][DF][E3][33][CA][0m
[33m SLCO NULL [0m
[33m Activity Update TS1: Idle; Hash: 0; TS2: Group Voice; Hash: 109;
SLCO Completed Block [10][80][06][D4][30]
[0m
20:11:55 Sync: +DMR slot1 [slot2] | Color Code=11 | VLC [32m
[0m
[0m
20:11:56 Sync: +DMR [slot1] slot2 | Color Code=11 | IDLE
20:11:56 Sync: +DMR slot1 [slot2] | Color Code=11 | VLC [32m
[0m
[0m
[0m
20:11:56 Sync: +DMR slot1 [slot2] | Color Code=11 | TLC [31m
[0m
[0m
[0m
[0m
[0m
20:11:57 Sync: +DMR slot1 [slot2] | Color Code=11 | TLC [31m
20:11:57 Sync: +DMR [slot1] slot2 | Color Code=11 | IDLE
[0m
[0m
[0m
lwvmobile
DSD-FME
Lafayette County, FL
Not sure, but considering its just a bunch of link control headers (VLC) followed by a bunch of link control termination headers (TLC) with no actual voice in-between, I'd consider it that somebody accidentally or intentionally hit the PTT for a split second and hung up, or their battery is dead. Just a guess.
