DSD+ how do i stretch this window horizontally?
EarHoles
New Zealand
This is the best i can get "full screen" with is only about 1/4 the screen, as you can see it cuts off information horizontally.
How can i stretch it across?
Most recent Fastlane release
slicerwizard
Toronto, Ontario
I just grab the right edge and drag it.
If DSD+ is being run from a .bat file, edit that file's properties (Layout tab) to make permanent changes.
EarHoles
New Zealand
i am unable to drag it across horizontally, i am able to vertically.
Yes i am using a .Bat which contains:
start FMP24.EXE -rc -i0 -o20001 -f163.18790 -n0 -g40
TIMEOUT 2
Start DSDPlus -r1 -T -fr -i20001 -OM NUL -PBmp3 -M32 -v4
BM82557
Berkeley Co WV
Try this -
Right click on the window
Then click on Properties
Then click on Layout
Under Window Size change Width and Height until you get it the way you want
Then click on OK
