DSD+ How does it run
Chris0516
Pittsboro, North Carolina
My question is because. I downloaded the Zip file. Then I extracted the contents. Wh3en I tried to run DSD+, I kept getting an error.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Also in your pic you can see where alphabetically between FMP-VC and LRRP.cfg there is no lame_enc.dll
redbeard
BEE00.348-3.1
And since you are using the old old old free version, you probably want to start it up using CC.bat rather than just clicking on dsdplus.exe. You can read what the various command line switches do in the txt files so you can craft a custom .bat file to start DSD+ how you would like it to.
Chris0516
It is giving me this error-
Initiating TCP connection to 127.0.01: 20001
TCP connect error= 10061
[no connection could be made because the target machine actively refused it]
u2brent
OAMPT
KRWDPAXKRS1
Using FMP requires that an SDR Dongle be inserted into the PC's USB Port and the correct drivers installed before starting. You don't use FMP if your input source is via a discriminator tapped scanner output, or using SDR# (or other program) to control tuning.
You need to read every txt file in the DSD directory.
Some additional info for getting started using many various devices and software can be found here.
This was a great help in getting myself started, Using this linked site and viewing a few videos available on the web.
Using the search function (usually on the top right corner of any of this sites pages) with specific errors will usually provide an answer or two about the issue from others who have already gotten to where you are at on your quest.
Kazzaw
South East QLD, Australia
You might need to do the driver installation from here
Follow instructions for setting up sdr# (even if you won't use it)
Chris0516
I am reading that now.
