DSD Plus DMR ERROR
Spartanman
Hi. I have found 2 frecuencies (164.3875/165.1375) and i don´t now what they are. I have tried decoding with simple DMR and DSD Plus but i dont get nothing. In DSD i get this: ¿Can i listen to it?
Captura de pantalla (162).pngCaptura de pantalla (165).pngCaptura de pantalla (166).png
racingfan360
It shows a Conventional DMR Repeater on 164.3875, but its only transmitting data and no voice. So there are no voice frames for DSD+ to decode.
racingfan360
It's simply beacon data, and DSD+ is already decoding the most useful data. So you're not missing out on anything !
Spartanman
Hi guys. Im trying to decode some DMR but i dont gent nothing. What can be?
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Yeah, under the audio tab. Filter Audio should be unchecked (looks like you have it unchecked)
You should:
a. set mode to NFM (not WFM)
b. change the Bandwidth from 32000 to 8000
If that doesn't work, you have other issues -- probably related to that plugin configuration, which is not standard.
mtindor
FMP24 PRO USER
That's only showing data "BS DATA". But there is more than one frequency on that Cap+ system. Rest channel is 3, which indicates there are (at least) two frequencies on that Cap+ site. The audio is likely occurring on another frequency.
If you DO hear audio but can't make sense of it, it's because Basic Privacy (BP) encryption is in use, along with some Enhanced Privacy (EP) as well.
Spartanman
You should:
I dont hear nothing with that configuration. I somethimes receive speech but is not clear.
Spartanman
If you DO hear audio but can't make sense of it, it's because Basic Privacy (BP) encryption is in use.
ouh, ill search for that freq
mtindor
FMP24 PRO USER
It's because the transmissions are encrypted. BP (basic privacy) and EP (enhanced privacy?) indicate encryption.
You can/should. But it may not be worth your time IF ALL traffic is encrypted.
Spartanman
Thanks for the help! Ill try finding it
