DSDPlus DSD+ preventing duplicate calls?
remmalsrood
DSD+ is great software but running more than 2 systems that can receive the same traffic at the same time can get confusing and loud. Is there a way to get DSD+ instances to work together so that if one talkgroup is talking on one system, the other instance somehow detects it and avoids that same call?
If that's not possible, what would be the easiest way to prevent this from happening, Splitting DSD into seperate folders and locking out talkgroups in one? But doing that might mean you'll miss calls due to one talkgroup being out of range of one system but not the other.
saioke
I'm not sure it's possible but would love to hear that it is.
Regardless, using rdio scanner to lock out duplicate calls is a godsend and a good method. But, it's also buggy. Sometimes duplicate calls can still get through in my experience, and sometimes the first half of a call can get cut off, so if a call is short, you won't even hear it.
Listening through rdio scanner also has a slight delay due to the way it works. DSD records .wav or .mp3 and then rdio scanner will import those recordings as calls. But, using it means you'll also only hear one call at a time if you're using multiple DSD instances.
