DSD+ ?!
Your_account
Banned
.AT
Code:
Sync:-DMR
-DMR  CACH ERR slot1         BS DATA       CC=1  CSBK
-DMR                slot2    BS DATA       CC=1  CSBK
-DMR           slot1         BS DATA       CC=1  CSBK
Sync: no sync
can someone explain to me what does it mean?
So its DMR thats clear but what is "CSBK" ?
Code:
Sync:-DMR
-DMR  CACH ERR slot1         BS DATA       CC=14  Idle
-DMR                slot2    BS DATA       CC=14  Idle
-DMR           slot1         BS DATA  ERR1 CC=14  Idle
-DMR           slot1         BS DATA       CC=14  Idle
-DMR  CACH ERR      slot2    BS DATA       CC=14  Idle
-DMR           slot1         BS DATA  ERR3 CC=14  Idle
-DMR                slot2    BS DATA  ERR2 CC=14  Idle
-DMR                slot2    BS DATA  ERR1 CC=14  Idle
-DMR           slot1         BS DATA  ERR2 CC=14  Idle
-DMR                slot2    BS DATA  ERR1 CC=14  Data Header
-DMR                slot2    BS DATA       CC=14  Data Header
-DMR                slot2    BS DATA  ERR1 CC=14  Rate 3/4 Data
CC=14 ???
ERR2 = Error?
CACH ERR = Cache Error?
EDIT2:
Code:
Sync:+D-STAR
Data:  U . .   . D I   U R E   C T     U   D   I R E   U C T       C   U Q C   Q
 C Q   U       O E 3   U D J   B       U I D   5 1 S   Q C f   f f f   f f f   f
 f f   <Resync>U . .   . D I   U R E   C T     U   D   I R E   U C T       C   U
 Q C   Q C Q   U       O E 3   U D J   B       U I D   5 1 S   Q C f   f f f   f
 f f   f f f   <Resync>5 $ $   C R C   5 2 E   8 3 ,   5 O E   3 D J   5 B -   5
 > A   5 P I   5 1 ,   5 D S   T A R   5 * :   / 1 4   5 1 2   4 9 h   5 4 8   3
 6 .   5 6 3   N / 0   <Resync>5 1 5   0 9 .   5 4 7   E [ 2   5 3 2   / 0 0   5
 0 /   A = 0   5 0 1   9 2 5   5 F r   i t z   1 . f   f f f   f f f   f f f   f
 f f   f f f   f f f   f f f   <Resync>U . .   . D I   U R E   C T     U   D   I
 R E   U C T       C   U Q C   Q C Q   U       O E 3   U D J   B       U I D   5
 1 S   Q C f   f f f   f f f   f f f   <Resync>U . .   . D I   U R E   C T     U
   D   I R E   U C T       C   U Q C   Q C Q   U       O E 3   U D J   B       U
 I D   5 1 S   Q C f   f f f   f f f   f f f   <Resync>U . .   . D I   U R E   C
 T     U   D   I R E   U C T       C   U Q C   Q C Q   U       O E 3   U D J   B
       U I D   5 1 S   Q C f   f f f   f f f   f f f   <Resync>5 $ $   C R C   5
 5 7   0 2 ,   5 O E   3 D J   5 B -   5 > A   5 P I   5 1 ,   5 D S   T A R   5
 * :   / 1 4   5 1 2   5 1 h   5 4 8   3 6 .   5 6 3   N / 0   <Resync>5 1 5   0
 9 .   5 4 7   E [ 2   5 3 2   / 0 0   5 0 /   A = 0   5 0 1   9 2 4   5 F r   i
 t z   1 . f   f f f   f f f   f f f   <EOT>
Sync: no sync
what does the letter mean?!
Forts
Ontario, Canada
The Wiki is your friend:
While decoding
CACH is Common Announcement Channel
TACT is TDMA Access Channel Type
LC is Link Control
EMB is Embedded signalling field
CSBK is Control Signalling Block
Not sure what you mean by the last letter... are you referring to <EOT> ? I presume that would be End Of Transmission.
D
DaveNF2G
Guest
The mass of miscellaneous letters in the DStar example means one of two things:
1) Your decode is not accurate. This seems unlikely as the received data are being formatted and labeled correctly.
2) Whatever is being sent is not plain text.
Your_account
Banned
.AT
i see a lot of strange text fragments over there...
its possible to send Data troth D-Star?
D
DaveNF2G
Guest
It is possible to send data using any mode, including analog AM. DStar is data.
CanesFan95
Was Homeboys-Scanna
Banned
FL
When I try to run DSD+ on D-Star, I get that exact same type of gobbldygook and no audio, even though I've got DSD+ working great on DMR.
Your_account
Banned
.AT
do you know the person who own the Gateway in your Area?
mikepdx
Corbett, OR USA
Start DSD 1.7 with these parameters to decode d-star.
dsd -i /dev/dsp -o /dev/dsp -fd
keep audio input level LOW.
D
DaveNF2G
Guest
There is a thread all about the introduction of DSD+. The information you seek is there and does not need to be repeated in this thread.
