DSDFASTLANE ISSUE
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I have run into this issue as well with 2.523
Here is my error message:
Error
FMP24 2.86 -i1 -o1
Unrecoverable error encountered:
Exception number = 0xC0000005 (Access Violation)
Instruction address = 0x41E36E
Action: Read of address 0x39AB050 (60469328)
Register dump:
DS: 0000002B CS: 00000023 IP: 0041E36E EAX: FF55FFB0
ES: 0000002B SS: 0000002B SP: 041DFF18 EBX: 00000000
FS: 00000053 Fl: 00010246 EBP: 041DFF24 ECX: 00012C00
GS: 0000002B ESI: 039AB050 EDI: 02F0B000 EDX: 00403E25
[Press Ctrl-C to copy this text to the clipboard]
I have also sent an e-mail to dsdfastlane@gmail.com
dave3825
Suffolk County NY
Shows in his pic he is running most recent and also shows hardware error which is usually either a usb issue or the dongle failing. Had a nooelec that popped a hardware message a while back. Dongle died.
The 0000002 one comes up on Google with a bunch of other stuff related to corrupt usb drivers.
I would try different ports and see what happens.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I had sent an e-mail this afternoon with the error text but failed to mention the 2p253 in that e-mail. A second e-mail has been sent tonight with that inclusion.
Thanks for some hope.
slicerwizard
Toronto, Ontario
Looks like a bad USB connection. Back in the TRUNK88 days, I found that a flaky connection could bork something in the rtl-sdr.dll code or in the libusb-1.0.dll code. Deal with the bad connection and the crashing will likely go away. In the past, I've bent the top metal plate of a dongle's USB connector down a bit to make it fit snugger and it definitely helped.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Fast Lane is still not working after gently pushing the connector and the USB ports in the computer.
Since I have other software, I tried this dongle with Unitrunker and SDRTrunk.
I next tried Unitrunker 2.1.0107 and it worked with Metrolinx sys:1AC on 410.2125 MHz 95 Health signal. When switching to LMRN site 40 on 142.905, I got zero Health signal.
SDRTrunk v0.6.0-alpha6 also works with the Peel 4F8 P25 800 MHz system. It sat Idle when switching over to LMRN Site 40 142.905 MHz
Interestingly, on both those programs I can't get VHF Hi to work but higher frequencies do work with this dongle. I went back to Fast Lane and I'm getting the receiver error immediately.
I'm using a FlightAware ProStick Plus. It is just not pulling in VHF any more. Go ahead, tell me the obvious.
