DSDPlus Decoding
UnknownAX
It's better but it won't fix a weak signal.
Hmm, does this look like a possible weak signal? I've tried playing with a few settings such as gain, PPM.
In the screenshot 'Capture' you can see the DSD+ window the audio wave seems to be at the top, is this normal?
Screenshot, 'Noise Filter 1' I attempted to try using a noise filter just to see if it would improve but nope. I also tried changing the band pass filter and this actually seemed to get some data but obviously still full of errors. At the top of the DSD it says S/S9600 and sometimes S/S4800, not sure if this helps to show a signal strength error?
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR2 DCC=11 Idle ERR34
+DMR slot1 BS DATA ERR1 DCC=11 Idle ERR54
Sync:+DMR
+DMR slot2 BS DATA ERR3 DCC=11 Unknown TypeF ERR1 []
57D6DEABA8471DF371
010101111101011011011110101010111010100001000111000111011111001101110001011110111101000100110110
+DMR CACH ERR slot1 BS DATA ERR1 DCC=11 CSBK ERR13 ECC FAIL
+DMR slot2 BS DATA ERR2 DCC=11 Idle ERR32
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR3 DCC=11 Rate 1 Data 57902C8B 214749DF 71339126 7A685425 75A40D86 9DFD655A 5
+DMR CACH ERR slot2 BS DATA ERR3 DCC=11 CSBK ERR14 ECC FAIL
Sync:+DMR
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR2 DCC=11 Idle ERR40
+DMR slot1 BS DATA ERR2 DCC=11 CSBK ERR13 ECC FAIL
+DMR CACH ERR slot2 BS DATA ERR3 DCC=2 CSBK ERR14 ECC FAIL
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR3 DCC=3 Unknown TypeC ERR1 []
577694254715513617
010101110111011010010100001001010100011100010101010100010011011000010111000110010101100110100101
+DMR CACH ERR slot2 BS DATA ERR3 DCC=3 Unknown TypeB ERR1 []
56D45A0F8146198669
010101101101010001011010000011111000000101000110000110011000011001101001111000101101000101110100
+DMR CACH ERR slot1 BS DATA ERR3 DCC=2 Unknown TypeD ERR1 ECC FAIL
+DMR slot2 BS DATA ERR2 DCC=11 Idle ERR50
Sync:+DMR
+DMR slot2 BS DATA ERR2 DCC=11 Idle ERR27
Sync:+DMR
+DMR slot2 BS DATA ERR1 DCC=11 Idle ERR50
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR1 DCC=11 Idle ERR50
+DMR slot1 BS DATA ERR3 DCC=11 Idle ERR57
Sync:+DMR
UnknownAX
Have you tried SDRTrunk yet? Should be able to run it natively on your mac.
Thank you, managed to get this working first time instead of using DSD. No errors or anything.
UnknownAX
Interestingly enough I believe I have also now discovered a CAP+ network. Time to start looking to see if it's possible to decode. I'd imagine not as it does say "CONTROL CHANNEL ENCRYPTED HEADER"
Code:
2021:11:28 23:13:21    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:22    DMR    0    CC:1 TERMINATOR [CRC-ERROR] FLC UNKNOWN OPCODE:44 MSG:2C0041008380800104409C06
2021:11:28 23:13:22    DMR    0    [CRC ERROR] SLC UNKNOWN OPCODE:5 MSG:5BB18
2021:11:28 23:13:21    DMR    0    <-> SYNC LOSS - BITS PROCESSED [4118]
2021:11:28 23:13:21    DMR    0    [CRC-ERROR] CC:9 MOTOROLA CAP+ SYSTEM STATUS [-L] REST LSN:4 LCN:2 MSG:3E108304460090010442D832
2021:11:28 23:13:21    DMR    0    <-> SYNC LOSS - BITS PROCESSED [1782]
2021:11:28 23:13:20    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:20    DMR    0    CC:10 CONTROL CHANNEL ENCRYPTED HEADER [CRC-ERROR] FLC UNKNOWN OPCODE:44 MSG:2C0000200300900B804099A7
2021:11:28 23:13:20    DMR    0    <-> SYNC LOSS - BITS PROCESSED [20]
2021:11:28 23:13:20    DMR    0    [CRC-ERROR] CC:9 CSBK *UNKNOWN* VENDOR:32 UNKNOWN OPCODE:60 MSG:3C208300020098030040D9A6
2021:11:28 23:13:20    DMR    0    [CRC ERROR] SLC UNKNOWN OPCODE:5 MSG:5FB30
2021:11:28 23:13:20    DMR    0    <-> SYNC LOSS - BITS PROCESSED [2728]
2021:11:28 23:13:21    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:19    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:19    DMR    0    [CRC-ERROR] CC:9 MOTOROLA CAP+ SYSTEM STATUS [-L] REST LSN:4 LCN:2 MSG:BE10830042000201000099B3
2021:11:28 23:13:19    DMR    0    <-> SYNC LOSS - BITS PROCESSED [7050]
2021:11:28 23:13:18    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:18    DMR    0    RATE 1/1 DATA CONFIRMED:1081E100EA092A4455184C28C0828D7F57D75D97D520 UNCONFIRMED:B2EB1081E100EA092A4455184C28C0828D7F57D75D97D520
2021:11:28 23:13:18    DMR    0    <-> SYNC LOSS - BITS PROCESSED [5294]
2021:11:28 23:13:17    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:18    DMR    0    RATE 3/4 DATA CONFIRMED:E56E7B5CC6CBCEAAF555E5BB33280AAB UNCONFIRMED:61AAE56E7B5CC6CBCEAAF555E5BB33280AAB
2021:11:28 23:13:18    DMR    0    <-> SYNC LOSS - BITS PROCESSED [6462]
2021:11:28 23:13:18    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:17    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:16    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:14    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:14    DMR    0    [CRC-ERROR] CC:9 CSBK *UNKNOWN* MOTOROLA CAP+ UNKNOWN OPCODE:58 MSG:3A1084010080800008000CBA
2021:11:28 23:13:14    DMR    0    [CRC ERROR] SLC TIER III TRAFFIC CHANNEL LARGE NET:11 SITE:16 SLOT COUNTER:0 MSG:3AC40
2021:11:28 23:13:14    DMR    0    <-> SYNC LOSS - BITS PROCESSED [8594]
2021:11:28 23:13:14    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:12    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:12    DMR    0    [CRC-ERROR] CC:1 USB DATA BLOCK TO:2097172 SERVICE:RESERVED 3 MSG:3A0000000280002000141E92
2021:11:28 23:13:12    DMR    0    <-> SYNC LOSS - BITS PROCESSED [4208]
2021:11:28 23:13:12    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:10    DMR    2    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:10    DMR    1    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:10    DMR    2    RATE 1/1 DATA CONFIRMED:7800F50292013C09801148105086AD7E53D75CF5D5A0 UNCONFIRMED:2CA87800F50292013C09801148105086AD7E53D75CF5D5A0
2021:11:28 23:13:10    DMR    0    <-> SYNC LOSS - BITS PROCESSED [3248]
2021:11:28 23:13:10    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:10    DMR    0    CC:1 CONTROL CHANNEL ENCRYPTED HEADER [CRC-ERROR] FLC UNKNOWN OPCODE:56 VENDOR:64 MSG:384014000380920000000A32
2021:11:28 23:13:10    DMR    0    [CRC ERROR] SLC HYTERA XPT FREE REPEATER:10 MSG:82CA0
2021:11:28 23:13:10    DMR    0    <-> SYNC LOSS - BITS PROCESSED [7466]
2021:11:28 23:13:10    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:09    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:08    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:07    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:06    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:04    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:04    DMR    0    [CRC-ERROR] CC:1 USB DATA BLOCK TO:196608 SERVICE:VENDOR SERVICE 3 MSG:AE800A000200D0030000BE8E
2021:11:28 23:13:04    DMR    0    <-> SYNC LOSS - BITS PROCESSED [2660]
2021:11:28 23:13:03    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:03    DMR    0    RATE 1/1 DATA CONFIRMED:1081A900EA00282455124C295006A8F755D75DF5D5A0 UNCONFIRMED:38EB1081A900EA00282455124C295006A8F755D75DF5D5A0
2021:11:28 23:13:03    DMR    0    <-> SYNC LOSS - BITS PROCESSED [606]
2021:11:28 23:13:03    DMR    0    [CRC-ERROR] CC:9 CSBK *UNKNOWN* UNKNOWN OPCODE:62 MSG:3E000200430090030A401B3E
2021:11:28 23:13:03    DMR    0    [CRC ERROR] SLC UNKNOWN OPCODE:5 MSG:51310
2021:11:28 23:13:03    DMR    0    <-> SYNC LOSS - BITS PROCESSED [720]
2021:11:28 23:13:04    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:03    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:13:01    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:01    DMR    0    [CRC-ERROR] CC:9 MOTOROLA CAP+ SYSTEM STATUS [FL] REST LSN:4 LCN:2 MSG:BE100300160A8001480099B2
2021:11:28 23:13:01    DMR    0    [CRC ERROR] SLC UNKNOWN OPCODE:4 MSG:4FB10
2021:11:28 23:13:01    DMR    0    <-> SYNC LOSS - BITS PROCESSED [1196]
2021:11:28 23:13:01    DMR    2    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:01    DMR    1    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:02    DMR    2    RATE 1/1 DATA CONFIRMED:A680E100EA002A0474124C294006A8FE57D75DF5D5A0 UNCONFIRMED:ADABA680E100EA002A0474124C294006A8FE57D75DF5D5A0
2021:11:28 23:13:02    DMR    1    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:02    DMR    0    <-> SYNC LOSS - BITS PROCESSED [7346]
2021:11:28 23:13:00    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:13:00    DMR    0    [CRC-ERROR] CC:9 CSBK *UNKNOWN* UNKNOWN OPCODE:62 MSG:BE004300020020010000AAD2
2021:11:28 23:13:00    DMR    0    <-> SYNC LOSS - BITS PROCESSED [2942]
2021:11:28 23:13:00    DMR    0    RATE 1/1 DATA CONFIRMED:D001A842E306C00B551932294006ADFE57925DF5D5A0 UNCONFIRMED:CBDCD001A842E306C00B551932294006ADFE57925DF5D5A0
2021:11:28 23:13:00    DMR    0    <-> SYNC LOSS - BITS PROCESSED [682]
2021:11:28 23:13:00    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:12:58    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:12:58    DMR    0    [CRC-ERROR] CC:9 CAP+ *UNKNOWN* CSBK:60 MSG:BC10E30000009003000019B3
2021:11:28 23:12:58    DMR    0    <-> SYNC LOSS - BITS PROCESSED [18]
2021:11:28 23:12:59    DMR    0    RATE 1/1 DATA CONFIRMED:0080E100BA01A80455124A285002A9FE57975DF5D5A0 UNCONFIRMED:B2EB0080E100BA01A80455124A285002A9FE57975DF5D5A0
2021:11:28 23:12:59    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:12:59    DMR    0    <-> SYNC LOSS - BITS PROCESSED [5302]
2021:11:28 23:12:58    DMR    0    [CRC-ERROR] CC:9 CSBK *UNKNOWN* VENDOR:80 UNKNOWN OPCODE:32 MSG:A0500FE426F83021B803551E
2021:11:28 23:12:58    DMR    0    [CRC ERROR] SLC UNKNOWN OPCODE:5 MSG:53B10
2021:11:28 23:12:58    DMR    0    <-> SYNC LOSS - BITS PROCESSED [1182]
2021:11:28 23:12:57    DMR    0    <-> SYNC LOSS - BITS PROCESSED [288]
2021:11:28 23:12:57    DMR    0    [CRC-ERROR] CC:9 CSBK *UNKNOWN* MOTOROLA CAP+ UNKNOWN OPCODE:58 MSG:BA10C300C08016000200BD87
2021:11:28 23:12:57    DMR    0    [CRC ERROR] SLC UNKNOWN OPCODE:5 MSG:5BB08
2021:11:28 23:12:57    DMR    0    <-> SYNC LOSS - BITS PROCESSED [606]
2021:11:28 23:12:58    DMR    0    RATE 3/4 DATA CONFIRMED:03DE92FDF5E03A90C87366CF550F0AAC UNCONFIRMED:A65403DE92FDF5E03A90C87366CF550F0AAC
2021:11:28 23:12:58    DMR    0    <-> SYNC LOSS - BITS PROCESSED [6262]
2021:11:28 23:12:57    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:12:56    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600]
2021:11:28 23:12:55    DMR    0    <-> SYNC LOSS - BITS PROCESSED [9600][/CODE
[/SPOILER]
Kazzaw
South East QLD, Australia
Is it a constant signal or one that comes and goes every 1-2 seconds?
I think you might be having signal issues with that one as well, as its picked up Cap+, TIII and XPT in your logs.
Regardless the encrypted header you see there I believe is data, so you may get voice
UnknownAX
It comes and goes it varies in time, generally 5-10 seconds. When it does come the waveform is a constant solid line on the program with no breaks in it.
The particular frequency is used by a large port. In total they have 24 frequencies listed which I retrieved from Ofcom (UK Body which companies have to register the frequencies with). The particular frequency I put into the program was the one which my HT seems to regularly stop in and show a signal but no voice as of yet.
noamlivne
Sync:+DMR
Sync:+DMR
57D6DEABA8471DF371
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
577694254715513617
56D45A0F8146198669
Sync:+DMR
Sync:+DMR
Sync:+DMR
Sync:+DMR
I would try also using the "b" or "B" key to change the bandwidth to something more closer to the signal's bandwidth.
dlwtrunked
Let me say it again: In my setup with DSD+, too strong of a signal will give errors just like too weak a signal. Also, the DMR I have by my side will not transmit voice if it is looking for a repeater (it looks for a handshake). I have to put it in talk-around mode for voice to be transmitted without a repeater.
