DsdPlus Fastlane errors after update
gm42uk
Hi, I was using the free Version of DsdPlus fine with a Hack rf and Sdr# ver 1700 using vb cable and yes i upgraded to the fast lane and now for the past 7 hours i have been wrestling with it trying to get it working,
if i try and launch from SDR# i get the Invalid command line parameter: '-dr0'
and if i try running dsdplus i get
Initiating FMPx link using link ID 20001...
FMPx link error = -5
[Server is not listening on selected link ID]
all i want to do is load SDR# then start DSDPlus like i did before the update i have tried removing DSDPlus and done a fresh install under the c:\dsdplus location but still the same errors, going back to about 2017 i had a dongle on fast lane with sdr# and upon upgrading that ran fine so could it be that the hack rf i have is not supported by the latest versions of the fastlane update maybe? im not sure and about to give up, so any ideas i would be grateful so i can get this up and running again cheers
CanesFan95
Analog already is interoperable.
FL
Why not use FMPx instead of SDR#? Then the FMPx linking should work.
Do tell us, how are you starting DSD+? -dr and -dh are no longer supported in Fast Line along with a few other command arguments. A lot of hotkeys were also eliminated. I don't believe HackRF is supported by DSD+.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Forget about using FMP* with a HackRF. When using SDR# + VBCable, execute DSDPlus, go to the Input menu and select the proper VB Cable and go to the CTRL menu and select Passive Digital Monitor. And forget the silly -dr0 commandline stuff. those "tuning" parameters are very much specific to certain bad signals you try to monitor. Putting those tuning parameters on the commandline, to be applied to bth good signals and bad can make truly good signal bad.
