Dsdplus fastlane problem after new PC
2e0wes
lower sackville
Hi guys, just got a windows 11 PC and now my fastlane isn't working. The hard drive that has the program on was removed for the old PC, and installed into the new, but now it says sdr 1 is in use, but it's not. Any advice pleases.
2e0wes
lower sackville
I did several times, but I've just figured it out. For some reason the system thought that there was 2 sdr available and change the default from 1 to 2. Not sure why, but it's working again now
dave3825
Suffolk County NY
So what did you change? FMP24 -i1 to FMP24 -i2 ?
You can change it to FMP24 -i0 which will use the first available dongle it sees.
What does your Windows device manager show as far as dongles and did you run Zadig on the new pc ?
2e0wes
lower sackville
You got it Dave, changed if from 1 to o, just confused me,as I set and forget, rathen than constant tweeks
dave3825
Suffolk County NY
How many dongles do you have and how many is the Windows device manager showing? And I hope that's a typo as its i0, not io
maus92
OCMD
I hope that you are not relying on that "old" HDD, lol. Transfer what you need to the new computer's HDD/SSD and relegate the old HDD to backups or the trash can.
