Dsdplus FL Line In Put
United Kingdom
Hi all I recently upgraded my computer to Windows 10 from Windows 7 . Am using my Aor3000A Plus radio with the discriminator cable to the Line input of the computer . It's works fine but I can't seem to be able to silence the background data noise. Anyone have any experience how to turn off the background noise ? Am using the Realtek windows audio driver . Any information would be appreciated.
dave3825
Suffolk County NY
Its been a while but try this.
Type Sound Settings into the box in bottom left, or how ever you open your Settings / Control Panel. When it opens, click Sound Control Panel on right under related settings. Click the Recording tab on the box that comes up. Select your input and choose properties. Locate the listen tab and uncheck the listen to this device. Click apply. It should stop the noise.
United Kingdom
Have tried that many times and it doesn't work . The data noise still there hmmmm
dave3825
Suffolk County NY
Are you selecting the correct input? While in DSDPlus, what settings are in use under the Input tab?
Try setting it to No Source Audio Monitoring.
United Kingdom
On the input on dsdplus . It's on Line In and no zsource Audio monitoring. Am not using vac but the discriminator output from my radio scanner into the line input of computer
gary123
try this as your .bat
start FMP24 -o7622 -fxxx.xxxx -b12.5 -g44.0
timeout /t 7
call dsdplus -i7622 -v3 -O NUL
this should work with the Synthesize all Digital Audio option enabled. In the same tab also make sure the volume level is set to 0db
Note: Enter in the proper frequency where fxxx.xxxx is
