Dsdplus lockout?
dave3825
Suffolk County NY
Is there any way to lock out a tg in dsdplus? I am using fmp to feed dsdplus.
I am listening to onevoice network and there appears to be a scrambled or encrypted tg on the system.
slicerwizard
Toronto, Ontario
When the talkgroup is active, right click on the talkgroup's number or name until the priority override shows L/O.
Code:
Channel Activity Window:
  Left click on priority    Increase traffic priority
  Right click on priority   Decrease traffic priority
  Left click on target      Increase priority override
  Right click on target     Decrease priority override   <---
  Left click on headings    Clear all lockouts
  Right click on headings   Clear hold
This assumes you're running a full trunking setup with two copies of DSD+.
dave3825
Suffolk County NY
Thank you, it works...But I am only running 1 instance of dsd.
That was going to be my next post.
When I start up, I launch in this order fmp-cc.bat, cc.bat, fmp-vc.bat.
With just those 3 bat files, I get the fmp tuner thats locked on the cc channel. I get a fmp tuner that displays a spectrum when there is voice activity and and I get one instance of dsd thats decoding audio and a dsd cc channel activity window that displays tx freq and talk groups
When I launch the last bat file,vc.bat, it comes up and the only thing that does anything, is the scope that it popped up. The vc dsd+ window will say no signal when there is no voice, and it says auto when there is voice. It does not display any thing other than the number of records saved. The dsd vc channel activity window does not display anything.
This is the last entry in the vc log
Code:
DSD+ 1.101pt
Program role is voice channel decoder; audio modes set to mono
Assuming FMP is signal source; auto polarity detect is disabled
Writing synthesized audio to per-call wav files
Source audio waveform window origin set to (400,210)
Source audio waveform window dimensions set to 100x200
Event log window origin set to (172,522)
Channel window origin set to (528,0)
Appending synthesized audio to file 'VC-DSDPlus.wav'
4 frequency records loaded
221 radio records loaded
59 group records loaded
0 site records loaded
0 network records loaded
Initiating TCP connection to 127.0.0.1:20002...
Connected to 127.0.0.1:20002
audio output device #1 = 'Speakers (Realtek High Definiti'
audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
audio output device #1 (Speakers (Realtek High Definiti) initialized
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
222 radio records loaded
223 radio records loaded
And the other issue is I see it tuning to "0.00000" some times. Does that mean I am missing a freq?
slicerwizard
Toronto, Ontario
You need to add accurate frequency entries for the system/site you're monitoring to the DSDPlus.frequencies file. If you haven't done that, the programs don't know what the voice frequencies are.
dave3825
Suffolk County NY
I did that. I entered all thats listed in the database.
Code:
; DSD+ frequency file
; you can edit this file while DSD+ is running
; line format:
;  protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
;  for TIII, siteNumber format = area.site
;   use site number = 0 for network-wide definition
;   use 0.0 for unknown frequencies
;   use sort order = 0 to sort by OTA channel number
; protocols:
;  D-Star
;  IDAS
;  NEXEDGE48
;  NEXEDGE96
;  dPMR
;  DMR
;  Cap+
;  Con+
;  TIII
;  P25
;  ProVoice
Con+, 171, 3, 1, 472.56250, 472.56250, 0
Con+, 171, 3, 2, 477.78750, 477.78750, 0
Con+, 171, 3, 3, 477.88750, 477.88750, 0
Con+, 171, 3, 4, 478.48750, 478.48750, 0
The cc is 477 8875
Tuning, It either to tunes to 478.4875 and at times says tuning to 0.0000 or something really low.
cg
Connecticut
In the database, there is a small grey number before the frequency. That is the channel number. Because there are 2 slots on each frequency, the database shows the odd numbers only.
003 (3) Selden Suffolk 01 472.56250c 03 477.78750c 05 477.88750c 07 478.48750c
Replace the 1, 2, 3, 4 that you have with 1, 3, 5,7 like this:
Con+, 171, 3, 3, 477.78750, 477.78750, 0
Con+, 171, 3, 5, 477.88750, 477.88750, 0
Con+, 171, 3, 7, 478.48750, 478.48750, 0
chris
nick223
Ottawa Illinois
Code:
Curious on what you mean by running a "true truncking" system operation with 2 instances of dsd+ ? Why do you need to run 2 dsd+'s
dave3825
Suffolk County NY
I to am curious because now that my second instance of dsd is running, I hear an echoing sound when both dsd's are decoding.
It seemed to be working fine with out launching the vc.bat, that load's dsd.
cg
Connecticut
You probably don't have the CC DSDPlus audio muted. When the voice channel is using the second slot of the frequency the control channel is using, you are most likely hearing audio from both instances of DSDPlus, CC & VC.
Try adding -o0 to the batch file or command line you use to start the CC DSDPlus
chris
cg
Connecticut
NO, you are running one copy of FMP and one copy of DSDPlus on the Control Channel and another set on whatever voice channel is in use.
If you don't mute the audio output of the CC setup with -o0, the CC copy will play any voice activity it sees on that frequency. Since the CC is on slot 1, any voice on slot 2 will be played by your CC DSDPlus. That same conversation will also be played by the VC DSDPlus setup, thus the echo.
One copy is to monitor and "decode" the control channel and then steer the second copy to the active voice channels and then "decode" the digital voice.
chris
slicerwizard
Toronto, Ontario
Trunking decoders typically use two receivers, one for the CC and the other for the VC. Most programs (TRUNK88, Unitrunker, ...) do all that with one copy of the program running, but DSD+ uses separate copies for the CC and VC tasks, so for a true trunking / voice following setup, you need to run two copies of DSD+. If you only run one copy, there is no way to follow specific talkgroups.
nick223
Ottawa Illinois
so im running the bat files a tapped scanner for CC and CC bat, FMPVC and VC bats I need to run another DSD?
cg
Connecticut
Kinda important to mention a tapped scanner.Tapped scanner replaces first copy of FMP
Tapped scanner monitors the CC. First copy of DSDPlus decodes the CC and tells FMP where to tune the SDR for the Voice Channel. Second copy of DSDPlus decodes voice and outputs it to speakers.
chris
