DSDPlus DSDPLUS Siteloader file missing
N1XDS
ÆS Ø
you don't need -rv & -rc if you do one dongle. Remove all but one good dongle from your system, and run it in 'combined CC/VC monitor' mode.
you will have one copy of FMP24 running, and then DSD+.
Code:
start cmd /c fmp24  -i"01" -o20001 -_2 -b9.5 -g36.4 -fXXX.XXXX
sleep 5
start cmd /c dsdplus -i20001 -f1 -o0 -PTmp3 -v0 -T -O NUL -- >> rec-XXXX.txt
this is the way I start mine, not with multiple batch files and all that jazz.
Okay I am lost when you say..Remove all but one good dongle..I only have one plugged in the USB port. Do you need me remove anything in the batch file for dsdplus or FMP24?
a417
we would need to see what you are trying to run, as I feel you've made quite a mess of each with all your changes. if it is easier, you can open 2 separate command interpreter windows and we can try to run things by hand until you know what works...
I may have misinterpreted , when you copypasta'ed that text load earlier, I thought you were trying to run multiple dongles.
