DSDPlus DSDPlus won't start
garys
Central Texas
Thanks. This brings up a second issue (of course). I can't remember how to access the menu. If it turns out I can't access the menu for some reason, then I think I have larger issue. I wonder if I should drop in the last good version of DSDPlus that I had even if it's from 2023?
Make sure you review the section in the Notes file: "Using DSD+ with external signal source" and make sure it's not set to do that. That option is used when you want to use a SDR program like SDR++ to hunt down signals and then use DSD+ to decode. I do this sometimes and have to change back to using FMPA for trunking. Can't remember what's it's called but it's in the same menu area of DSD+ as the external signal source.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
The menu is available by default on the newer stuff. You should be able to click on INPUT, OUTPUT, CTRL, etc. and should be able to have a pull-down menu.
dkcorlfla
Orlando
Here is a SS, as they say a picture is worth a thousand words ;-)
garys
Central Texas
I am not seeing any of that. I wonder if there was a problem with the download and files go corrupted.
garys
Central Texas
It's fixed. You aren't going to believe I could be so dumb, but I was. I dropped the new DSDPlus.exe into the wrong directory.
It's only third on the list of dumbest things I did last week, which is kind of sad. Now I just have to clean up some minor stuff and get back trying to sort out the trunk system.
Thanks to everyone for their suggestions and help.
