Dual 05 Mounting Options
jtm1816
Martinez, GA
Looking to mount two 05 control heads on the mounting arm i have installed. I have the brackets but i am struggling for ideas on the best way to mount them.
i was thinking something similar to this and just turning it vertical! This just mount the brackets to it
Ibolt Mount
However, I wanted to see if anyone would share some pictures or ideas of their dual head setups.
nhfdcadet
CETsr
New Hartford, Ct
Ibolt Mount
is this going on like a ram mount or similar thing? That fish finder mount you linked looks like it would work fine for that
jtm1816
Martinez, GA
It is in fact going on a ram(ibolt) style mount. I decided to go with the plate from Amazon. Once i get the other bracket in, i will share a picture of the completed mount.
a417
perspective really decieves ya, huh?
jtm1816
Martinez, GA
It definitely draws the eyes more to the bottom one. Its taking some getting used to honestly.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Can you post a picture from the back showing the mount?
ThreatLevelMidnight
Georgia
Would be nice if motorola would produce a dual control head trunnion similar to the dual deck trunnion. (HLN7045A)
merlin
DN32su
OK , I think I see what you have in mind. Just uncommon for two local heads.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
why not just use one mount, and a couple pieces of flat aluminum to extend from the thumb screws up to the next head, just stack them right on top of eachother
That's what I did in a work vehicle. First control head used a regular bracket and then the second control head used a couple of flat steel pieces to secure it to the first.
vagrant
ker-muhj-uhn
California
I have/rigged a dual control head mount as well. It works very well even with non paved roads. VHF/UHF & HF control heads. Flexible arm using a seat bolt mount. It’s either a RAM or Lido. I also used a flat piece as well. A few small bolts and nuts from Lowe’s and done. Yaesu 400XDR and a Kenwood 480SAT, so not the lightest control heads.
