I recently purchased an Ed Fong DBJ-1 dual band VHF/UHF antenna with the intention to use it as a scanner base antenna. It will be mounted on the roof of the house with approximately 30-50 feet of RG8U coax (that I had already) routed through the attic and down into the house. The antenna end will have an N connector and the scanner end a BNC. I am located in a very rural mountainous area where I will be only monitoring 150-160 MHz and 450-460 MHz decoding P25. I am close enough to the two main sites I want to monitor to sporadically receive inside the house with a rubber duck antenna. Does anyone foresee any problems using this antenna for a scanner. Thanks in advance.
