Duplex Repeater/Antenna Question
emtunderwood
In a P25 VHF Repeater with duplexer what would the best noise for or rx threshold to use on a prop study? Is that at what db the repeater opens or what should i use, can someone explain?
lenk911
St Paul, MN
This varies by the environment the fixed station is installed in. Coverage study convention is manmade ambient noise = 3 to 25 db. I have measured 25 db at a new fire station with LED "florescent style" lighting. Lights on = 25 db. Lights off about 8 db.
You have other losses you must account-for to be accurate.
Noise at the subscriber end.
TSB-88 losses on both ends.
Co-channel interference loss at both ends if any.
The manmade noise is due to non-transformer power supplies (Buck Converters, wall warts etc.), LED lighting and their controls.
