Duplexers?
hdsae60
Who sells duplexers for 100 watt repeaters? Any suggestions...
buddrousa
Your local 2way radio shop sells them. You still to have to have a tracking generator to tune them and it is better if they are hooked to the antenna system they are to be used on. I do not trust used duplexers, hardline or antennas.
Telewave Inc. has been who we've been using the last few years. You can order them tuned to match your system, but that depends on them not being beat up in shipping/install. As you'd expect, double checking them after install is a good idea.
hdsae60
I have a IFR 1200S and the knowledge required to tune a duplexer. What I need is a online supplier to buy from. The radio shop closest to me doesn't have a clue. They did try to sell me Direct TV and a home security system though.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Sinclair Technologies. They offer both traditional 'cans' and Resloc's 4-6 cavity.
They are usually rated for 250-300w.
kayn1n32008
Sector 001
I guess bpbr is a thing of the past?
No. Why do you ask? You can get BpBr from Sinclair in both the traditional style individual cans, or Sinclair also offers BpBr in their Resloc series.
Myself, I would use the Resloc's, they work very well, can offer upwards of 100db of isolation, and take up a bit less room in the rack. They can also be mounted horizontal or vertical, as the rack wings are fully adjustable.
N5TWB
Sand Springs OK
I'm the president of an amateur radio club that just bought new duplexers for a problem location where the repeater is co-located with a commercial FM station. Our engineering committee recommended Bird Technologies for the best isolation. We bought a 6-can setup for our 2-meter split and it's made a world of difference in the performance of the repeater. The isolation improvement allowed the transmitter output to be punched up without getting into the receiver. The phone number is 800-866-8979, x5062 for Andrew Johnson. Amateur discount price was $2100 plus shipping for model #28-37-11E.
jeatock
090-45-50 W, 39-43-22 N
I have played with most makes of filters and duplexers, and have come to this conclusion: You get what you paid for, no matter who made it.
I maintain several sites with EMR filter systems. FOUR 100w repeaters on shared antennas. Pricey, but they rock.
12dbsinad
I have had good luck with TXRX (Bird Technologies) brand of duplexers. I have some that are over 25 years old and they still work like day one. I have found they handle the best with high power stations compared to some other brands I have used.
Make sure you don't stop at purchasing a high quality duplexer though. How it gets installed and cabled up can make or break a system regardless of what duplexer you use. Many times I have seen a 2000+ dollar duplexer get cabled with cheap non shielded RG-58 and braided RG-8 style cable on the output.
jeatock
At the risk of repeating myself (I'm going to anyway):
A $5,000 antenna system and a $50 radio will outperform a $50 antenna system and a $5,000 radio every time.
Inglewood
+1 on the Sinclair via Tessco. You don't say if it's for VHF our UHF, but if UHF Sinclair do three different designs with different isolation specs depending on your power, tx/rx split, and space requirements. If VHF mount them vertically if possible, over 10 years or more VHF duplexers on their side will drift.
ElroyJetson
Absolutely do not buy any duplexer made in China. I've tuned hundreds of duplexers and every Chinese one I encountered got beaten with a hammer and recycled for scrap metal when I determined that they would not tune properly and performed so badly that they were likely to damage the repeaters they were to be connected to.
