E evans creek fire
amr_emt_907
la pine, OR
Does anyone know what radio frequencies i should monitor for this incident and has anyone been monitoring the radio comms. Also i am in shady cove so I am wondering if I would even be able to even listen to the majority of it. Such as the tacs channels.
Bowlieweekender
Encryption is Easy - Key Management is Hard
Prineville Oregon
I know for Central Oregon but don't know the name of that particular fire, what area is it?
kd7jfv
Bend, Oregon
Here's a start for you, TFR is 118.3 and this is usually the Air Attack frequency.
CKScripts
Greetings,
Can't say I know much about this area whatsoever, but I've got some forestry frequencies to help you monitor the action.
Rogue and Medford ODF Aviation
Channel
RX
RX Tone
Notes
Local Flight Follow166.787567.0N/A
National Flight Follow168.650110.9N/A
FM Air Guard168.625NoneAll Aircraft Must Monitor
Air-to-Ground 51168.3125OR 03 Primary
Air-to-Ground 62169.3625OR 03 Secondary
ODF White (A-G 01)151.310156.7ODF Primary Air-to-Ground
ODF Blue159.2625156.7ODF Secondary Air-to-Ground
ODF Orange156.0225156.7ODF Air-to-Ground
Air-to-Air 1 OR 03124.475OR 03 Primary (AM)
Air-to-Air 2 OR 03132.725OR 03 Secondary (AM)
Air-to-Air 3 OR 03133.425OR 03 Tertiary (AM)
Medford Tanker Base122.675 Ramp (AM)
Rogue River National Forest (OR-RSF)
Channel
RX
RX Tone
Notes
High Cascades Ranger District169.57567.0Hershberger, Halls Point, Rustler, Devils Peak (Seasonal), and Robinson Butte
Siskiyou Mountains Ranger District169.97567.0Whiskey Peak, Dutchman, and Table Mountain USFS
Medford District BLM (OR-MED)
Channel
RX
RX Tone
Notes
Medford District BLM172.450N/ANine Mile, Cedar Springs, Onion Mountain BLM, Flounce Rock, Tallowbox, and Table Mountain BLM
Medford ODF
Channel
RX
RX Tone
Notes
Medford ODF151.175179.9Flounce Rock, Roxy Ann (Primary), Tallowbox, and Soda Mtn
The forestry tacs like "USFS Project #" or OSFM you very likely won't be able to hear, so I'd stick with repeaters unless you're crazy close or something, but you should totally be able to hear the repeaters from where you are. I've listed the repeater locations of each channel in the notes so you can see if they're nearby, but I'm pretty sure all are within range of you. It may also be worth listening to Jackson County's North Fire Dispatch.
Jackson County Fire
Channel
RX
RX Tone
Notes
North Fire Dispatch154.130162.2N/A
Lastly, you may be able to watch from afar from the ALERTWest Long Mountain fire camera. Let me know if these work or help you out.
CKScripts
