East Idaho Garden Creek Fire - NE of Fort Hall, East of Blackfoot - Frequencies
thewenk
Idaho DB Admin
Eastern Idaho
In use BLM aircraft and Dispatch frequencies active now.
5 additional Air Tankers inbound from Calif and Utah ( as of 1700 hours 7/1)
Load and reload at Pocatello
Air-Air Fixed wing- 124.4750
Air-Air Rotors - 125.7750
Air-Ground 49 -168.0375
E Idaho BLM Net UHF - 408.475
E Idaho BLM Net - 169.775
es93546
A Member Twice
Right Side of CA on maps
Note that the UHF frequency is a link, not a field frequency.
ecps92
Taxachusetts
Any PL's on those two E Idaho BLM nets ?
As Fred indicates the UHF is likely a downlink from a remote RX site - so you hear what Dispatch/Field Offices are also hearing
thewenk
Idaho DB Admin
Eastern Idaho
103.5 PL for he BLM nets.
Thank you. I am well aware of the UHF links and how they are used. In some areas the the UHF has better reception than the VHF.
ecps92
Taxachusetts
if you hear them using Repeater named, feel free to post here and I can update the wiki (most folks not familiar with the wiki edit)
Many folks are not familiar with the UHF, and yup depending on the beam from it back to Dispatch it sure does enhance reception
es93546
A Member Twice
The comment was not meant for you, it was for other readers who don't understand system links. I often see posts here on RR where people call the UHF system some sort of field system that simulcasts what is on VHF.
