Eastern Panhandle 452.2000 NXDN
BM82557
Berkeley Co WV
Anybody in the Eastern Panhandle or surrounding areas of VA/MD/PA want to check 452.2000? It's a NEXEDGE48 control channel, site L428-1, RAN 1. I see Meritus Medical in Hagerstown has 452.2000 on a license (WPPW946) with an emission of 4K00F1E and 11K2F3E but the RR db has them as LTR analog. Maybe they've switched to NXDN?
BM82557
Berkeley Co WV
From 2/23 -
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
You probaby nailed it. Even though the LTR system only lists three frequencies, the license lists five frequencies. If it is them, it looks like they have simplified things by just using ch. 1-5 instead random stuff. And 452.200 (the cc) is ch.1, so maybe they go up in order 1-5 from lowest to highest freq.
Might want to add something like this to the various DSDPlus files:
DSDPlus.networks
NEXEDGE48,428,"Possibly Meritus Medical Center"
DSDPlus.sites
NEXEDGE48,428,1,"MMC"
DSDPlus.frequencies
NEXEDGE48,428,1,1,452.20000,457.20000,1
NEXEDGE48,428,1,2,453.00000,458.00000,2
NEXEDGE48,428,1,3,461.90000,466.90000,3
NEXEDGE48,428,1,4,463.47500,468.47500,4
NEXEDGE48,428,1,5,464.06250,469.06250,5
Then monitor the system. When you see the traffic switch to a particular frequency, if you have a scanner available you might want to tune to that frequency. Heck, if you have a scanner available you might want to add all of the frequencies in there (except perhaps the active control channel).
Then, even if you don't have a scanner that handles NXDN, at least you'll be able to scan the five frequencies and when it stops on a freq and you hear digital noise, look at the DSDPlus screen and see which ch # is showing as active.
That's one way to tell if you've got the right order.
If you don't have a scanner that'll do NXDN, you can set DSDPlus up to scan the five frequencies in a frequency list (I've never done it) and it would stop on any active channel and play the audio.
At any rate, you've given plenty of information so that anyone else in the area might be able to confirm whether or not its MMC and what the ch # to freq pairings are.
Mike
