Eaton County Fire Dispatching
gpp10x
MI
I want to program a scanner for Eaton County Fire dispatching. I see 460.625 but I also see Grand Ledge, Charlotte and several other communities with their own fire dispatch frequency. Are these other freqs used for dispatching instead or in place of 460.625. Thanks in advance.
gg750
Traverse City, MI
I know Delta Twp. dispatches on their own frequency, but I don't know about the other communities.
rdale
Lansing, MI
GL too. Only on their frequency.
gpp10x
MI
Ok, thank you for the replies. I'll add the other freqs for my listening pleasures.
scannerman5000
Eaton Rapids, Michigan
All those frequencies that you see are the correct frequencies.
I will give you a complete list here now.
Eaton County
FIRE DISPATCH FREQUENCIES
460.625 Eaton Co. Fire main
453.400 Charlotte Fire dispatch
453.625 Olivet Fire dispatch
453.425 Bellevue Fire dispatch
453.450 Sunfield Fire dispatch
460.575 Delta Twp. Fire dispatch
460.150 Grand Ledge Fire dispatch
FIREGROUND/MUTUAL AID FREQUENCIES
453.550 Eaton Rapids area fire ground
460.225 Windsor Twp. fire ground
453.825 Charlotte fire ground
460.525 Delta Twp. Fire ground
453.150 Eaton Co. ADMIN/Disaster
453.750 Tri County fire mutual aid
453.2125 U-Call (UHF interoperability channel)
453.4625 U-tac 1(“” “ “ “ )
453.7125 U-tac 2(“” “ “ “ )
453.8625 U-tac 3 (“” “ “ “ )
(Note: for agencies not listed, they usually use the “talk around” frequency of their dispatch channel. Try monitoring the dispatch frequency first)
tobin343
Lansing Mi
can anyone tell me whats the difference between Delta Twp Still Alarm and Delta twp All Call for toneouts wanna know what they both are being used for
fdhuyvetter
Eaton Rapids,Michigan
Delta Still alarm activates all 3 stations but not the off-duty/volunteers vs the ALL CALL that activates the stations and off duty pagers. ALL CALL is generally only used for reported structure fires
